Cup 182
Whats the best type of oil to put in my 182 and it seems to be leeking from sum were any ideas
He thanks mate and its leeking from bottom .Leaking from the top, bottom?
Stick any oil in that's 5w40 and meets RN700/710 spec.
Its not cum from the backThe sump you think? If it is then if you get it sorted, fit some ARP rod bolts while you're there.
Are you sure it's not leaking from the rocker cover and down the back?
its coming from the front mate not the back but the top but cumin from underneith thanks for the adviceThe sump you think? If it is then if you get it sorted, fit some ARP rod bolts while you're there.
