Towing car
Car  Clio 172 phase 1
Want to get a trailer and start towing my ph1 to track, what car do you guys use to tow? want to spend about £800 so nothing special just somthing good on fuel and tow easily
I tow my 1000kg clio on a 1300kg single axle trailer behind my daily drive Vw bora tdi.
A LOT depends on your license and whether youre buying or hiring a trailer.
I'll be buying a trailer or a good dolly, my licence I can tow a combined weight of 3500kg so that's both cars and trailer
There are no good dollies, as they are illegal for anything other than recovery, so it's a trailer.
3500 restriction means post 97 like mine, or post 2013 where the rules are slightly different.
Be careful though, as its not simply a 3500kg restriction. For 1997-2013 you need the following:
  • MAM (gross weight) of the trailer must be less than the unladen weight of a towing vehicle
  • MAM of the towing vehicle and MAM of the trailer must be less than 3500kg
and then implied within this
  • You must not exceed the MAM of the towing vehicle
  • You must not exceed the manufacturers towing limit
  • You must not exceed the net weight of the trailer.
Sadly this means I cant tow a hired trailer with the bora, because the trailer MAM will be 1800-2600kg depending for most twin axle trailers
I also cant tow my trailer behind an empty van, as the MAM of the van puts me over too.
EDIT: Interestingly the rules seem to have vanished from the gov.uk website, so perhaps it's been relaxed...
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/447803/INF30_130715.pdf
I bought a Mondeo 2.2 ST TDCI hatch (kerb weight 1475kg) for work and trailering the Clio, its been very reliable and puts out a real world 45-50 mpg and is pretty nippy with 155hp/360nm so good for pulling. Pick them up for peanuts now and they have a 1800kg towing capacity, the transporter I use is a twin axel (14ft x 6ft/2700 GW) and weighs in around 600kg so the hire place state so towing the <1000kg Clio with a few spare parts like wheels and garage equipment is fine.
