Missfire under load
  Clio sport 172
Hi guys wonder if someone could belp me here
I have an 02 plate 172 it developed a mossfire over night a couple days ago and was there for a couple days then went away but came back again yesterday i have already changed the coil pack and leads and the plugs havent been in the car for very long any ideas would be appreciated
  PH2 172
Did you fit the recommended PFR6E-10 NGK Platinum plugs?
R3k1355
Do you get any warning lights on the dash when it misfires?
Injectors are another possibility.
  Clio sport 172
The E/M light flashes when missfiring and the service light cmae on last night which im guessing is to do with the missfire
Rojer
Best way to do it is plug in a code reader, they are relatively cheap at £25/30 each, but don't replace them before you have checked the plugs first and plugged it in.
  Clio sport 172
Okay cheers will take the plugs out and check them the car has always had a rough idle though i know there meant to but mines osnt great but will get it plugges in and see what it says thanks for the help
KitsonRis
Another way of checking is to un plug an injector while the car is running and if it gets worse and goes to 2 cylinders then that injector is OK. If there is no change then that injector is at fault.
Renparts on eBay do new genuine injectors for ~£35 each (or they did when I bought them last summer). What I would do is change all four anyway if they haven't been done before. Doing all four of mine along with a new coil pack and HT leads did make a difference to how the car drove.
Coops Mk1
  Lots of Scrap...
as above, easiest check is just to unplug each injector in turn and listen to engine note change, no change = fubar injector
  Clio sport 172
Just an update on the problem git the car plugged in to find out what injector had gone and it said number 3 has gone so just waiting on new ones coming and gonna replave all 4 as the injectors have been on from new. Thanks for the help guys
