Ph1 engine in 182?
Car  Megane R26
Can't find much under search, just a quick question.
Ph1 engine.. Will it be good to go into my 182?
What do I need to swap over or consider?
Ph1 clutch same as 182?
Thanks!
I have a Ph1 in mine. Inlets (and pretty much everything else) carried over from my damaged 182 engine. Same clutch (although I got a new one as the engine was already out = no labour cost).
I didn't do the change myself (Rentech did it) so can't give you specifics. But from my discussions with Mike, theres a fairly unimportant bolt that can't be fitted properly on the upper inlet and a spare pipe to block off.
Appreciate the info!
I have potentially found a ph1 engine. I'm after a 182 ideally but haven't spotted any apart from the odd one from a breakers and I rather get you off a forum member
