So before i went on holiday the car was flickering with the STOP and battery lights on and off. I was told it would be the alternator so i swapped it for a new one. When it was fitted i still had the lights coming on under hard acceleration. I think the plug wasn't in properly and since i took the plug out and pushed it in it was fine. Went out tonight and at the top of the revs the lights are coming on again. Does anyone have any ideas what this might be. I'm pretty sure the battery is fine and obviously the alternator is new so must be wiring or something right? Its probably going to be quite hard to check continuity on the wire because it goes to the clocks.
