Acceptable work? Decat fitting
  Clio 182 Trophy
Left my car with the local garage today (not used them before) to fit decat pipe.
Over the phone they said they'd clamp it and it'd be fine etc.. picked it up this evening and got this (pics below). Doesn't look great to me but does it look acceptable? It now sticks out an extra 2" and they didn't bother putting it back in the hanger properly it seems. Thoughts?
Udder Nonce
I Park Like a C**t
That's not acceptable, no.
But to be fair, the decat may have been badly fitting. It running an olive joint? Looks to be. Get powerflex rear bushes so they can't actually raise the back boxes.
  monaco 172
The tail pipes no. But 182 decats do clamp onto the centre section as it uses an olive joint unless you buy a sleeved decat.
Although I'd personally never use that fire putty crap as it sets hard as nails and cracks to bits. I always use high temp black silicone
MRBILLYUK
  FF Jeden Osiem Dwa
First of all , the decat does sweet FA , other than increase the exhaust noise . Then you're gonna have the hassle of swapping it back come MOT time . As said above , that putty will crack and drop off in next to no time . I'll put money on that clamp working loose too . As for the tail pipes sticking that far out , that looks a mess and not acceptable . Plus your exhaust hanger looks cream crackered , it's split and collapsed .
You took it to a garage not an exhaust place I take it ?
  Clio 182 Trophy
Thanks for the replies.
It was hanging absolutely fine before and both of the bushes are in decent condition. The end they've clamped didn't have an olive joint so it's sleeved in and clamped.
Looks like I might be getting them to put it back to standard and going elsewhere or hope a oe cat turns up for sale that goes straight in.
  Clio 182 Trophy
Garage shut at half 5 and I couldn't collect til after work at 8 so didn't get a chance to look unfortunately. I'll be on the phone tomorrow morning
MRBILLYUK
  FF Jeden Osiem Dwa
It's sleeved you say ? So can the exhaust be adjusted , as in pushed further back so it's not sticking out as much ? Like I said , I wouldn't bother with the decat in the first place , they don't give any extra performance , just noise . I took mine off and sold it cos I couldn't be arsed farting about with it come MOT time. See if the garage will rectify it , they should do really , but I'd be tempted to take it to a proper exhaust place.
Udder Nonce
I Park Like a C**t
Looks to be that the decat isn't fully sat with the sleeved portion inside the centre section. So its consequently pushing the centre section up causing the back box to sit downwards. What makes the decat?
  Clio 182 Trophy
Yes I'm not sure what they've chopped and shoved where TBH. This is a pic I took before just to see the length difference.
  Clio 182 Trophy
Looks like a Milltek decat to me. That photo makes it look like the wrong decat for the exhaust.
what make is the exhaust
One of the later btm one's and it's a milltek decat. I did ask the garage to look to see if it'd work first before fitting hoping that if it obviously wouldn't fit they'd be professional and tell me no.
DrR
  VW Golf GTD
Iirc yozzasport decat was the only one with the slight kink in, the rest are straight, which isn't correct.
  Clio 182 Trophy
you probley needed the the scorpion decat as it olive jointed but that wont fit now as they've cut the joint
http://www.ebay.co.uk/itm/Renault-C...119938?hash=item33d5ab8582:g:rDQAAOSwAyBZpcaL
i think the milltek decat will need a couple cm's cut off it now so the exhaust can be pushed back so the tail pipes sit further in
Yeh that looks like a much better fitting! I told them on the phone to not chop anything as I wanted it undo-able. Hopefully they haven't cut the centre section although looks like they may have
Gus
  182Turbo,DCi90
sorry just caught up. yes - looks like they have cut the olive joint part.
  Clio 182 Trophy
I'm going to leave it with the garage again today and tell them to put it back to how it was before with my oe cat. It still works but it's got rusty and slightly broken flanges. I'll call you later if I'm stuck, cheers mate!
Garage was 4winds, near abingdon.
Udder Nonce
I Park Like a C**t
You'll have to have for cat sleeved now for it to fit again if they've removed your olive.
  Clio 182 Trophy
Hopefully the cats gone over the centre section joint...
UPDATE - Took it back this morning and explained I wasn't happy at all, he said he'd have a look on the ramps but "that's the problem with these aftermarket parts". Anyway, got to work and he called me saying the fitting looks perfect and the tips are sat how they were when I brought it in (luckily we're sad and all have pictures of our exhausts). He invited me to go and show him what I mean, so I'll be back there in my lunch break to point it all out.
  dan's cast offs.
the guys obviously a cockjockey coming out with that!! to be honest i'd just say cut your losses and go somewhere else.
if you're fitting a customer supplied part and it 'looks like it won't fit' it's common sense to phone and speak to them before you do anything let alone go cutting/modifying things to make it fit.
leedsboy
  Bean 182 + E70 X5
Dare we ask how much you were charged for it?
Happy days if they've got it sitting properly now but looking at the first attempt, I wouldn't hold my breath.
  Clio 182 Trophy
2 hours labour, so £120. Not the end of the world but still a shitter
£120 to fit a decat...and badly at that, wow! I'd be demanding my money back and the cost to have it rectified at another garage. It took me 20 minutes to fit my decat and that was on axel stands, robbing bstards!
  dan's cast offs.
i'd still be asking for full refund on it. not sure what protection you get with debit card though?
  Clio 182 Trophy
Not much I don't believe. An error on my part but then I shouldn't be in the position. Will see what the guy has to say later and give him one chance to put it right
  Golf 7.5R & Clio 200
You still get a lot of protection. May even be able to claim distance selling as the work was done and paid for without you viewing, if needs be.
Daniel
  Whichever has fuel
That is dreadful workmanship, absolutely appalling.
And to charge £120 to fit it is nothing short of a total rip off.
I'd be looking for a new 'mechanic' to work on your car in future. I wouldn't let him top up my screenwash the 2 bob pirate.
leedsboy
  Bean 182 + E70 X5
Without putting the fear in you even more, I'd be worried to see what's under all that putty.
  Clio 182 Trophy
At the garage right now and he's just putting it on the ramp... I called to say I'd be 15 minutes and it seems the owner has now 'gone out for a bit'
  Clio 182 Trophy
Ask for a refund, 120 is mental money. Was that an agreed price?
Was it ktec lol.
No not agreed price. Possibly my fault again but I (stupidly) like to trust people.
Got in the pit with the guy working their and took some pics. He's hung it properly now so it's straight, just sticks out. He said they could cut it down etc etc but I wouldn't trust them anymore. Pics now.
Think I'll cut my losses and just get a better fitting cat on asap :(
Mr R.
  A special one.
You really need a new exhaust fitting kit mate.
And what's the crack with all that exhaust paste sh1t?
davo172
  TCR'd 172
Lools like Andy from clioturbo quality workmanship!
Seriously thou that is a real s**t job did you pay him before he fitted it then ?
No way I would of paid for that afterwards and 120 for 2 hours flol is it a main dealer :fearscream::fearscream:!
  Clio 182 Trophy
Some crappy sealant stuff they use that looks like they threw it on from 50 yards away. That mani to cat fitting kit was new in feb, surely they don't go that quick? Unless you mean something else.
I paid over the phone before I saw it, won't be doing that again!
So what's the best way of me getting any/some of this money back? Considering everyone can see how bad it is. I showed him the before pic (below) and he still ummed and ahhhed.
Mr R.
  A special one.
I was mate, I'm sure there's bits missing and I take it that there's a penny washer fitted to the end on the bolt because the manifold flange is rusting away.
