  ford fiesta 2004
Did this at bedford yesterday. Grrr.
Trims sprayed satin black to go with the speedo trim. Want to have the elf letters on the left trim but trying to work out the best way for it, need a sort of clear sticker with just the white lettering on really as cutting up the sticker is effort
Going for this look
  200 RS 2010
changed all 6 interior bulbs to white led's, then when trying to do the same with the number plate lights broke both of the housings! Woohoo, eurocarparts, £11 pick up replacements tomorrow, gimp!
  clio2 2001 1.9dti
Changed the LH lower arm on MK2. Had a problem with replacing the old bush link between roll bar and arm, trying to squash it enough to get the nut on underneath. Why couldn't they make the bolt a bit longer?
  PH1 V6
Collected my PH2 wheels yesterday.
Tyres on today and wheels done with C5, will be on the car tomorrow.
Also just heard my coilovers have been delivered!
It's getting there :up:
  Megane R26
Ktec stealth Supersport fitted.
It's VERY loud! A low bassy note that resonates through the cabin, really not a fan. It still has the cat.i hope the note chances to more raspy when I fit my 182 manifold..
  200 RS 2010
brought 2 x Christmas trees home in it.. so got home and bought a handheld car vacuum cleaner, Autoglym interior shampoo and an upholstery brush.. fix the mess Tuesday :)
  RB Clio 182
I wish my miltek was louder, it looks like its a silenced one with the cat still in place, so i may get a decat and the silencer removed.
  A special one.
Gave the old bus a wash, it hasn't been washed in 2 month's or so.
Today I will be waxing/sealing the paint ready for the winter grime. [emoji5]
chris blue
  clio rs 220 trophy
Brake pads front, 20mm spacers, and 16mm spacers back. Pleased no rubbing on the (Lowered) backs, as 20mms back did rub
and finished off with a nice clean :)
  182FF - Land Rover
It sounds standard tbh mate, with a little zest, the induction kit sounds awesome so im happy now. Cant even here the miltek because of it lol.
I have a Milltek non-resonated centre section I'd part with (needed to be quite on mine!)
Was on the car a week, so its almost as new, with clamp etc.
  BMW 320d SE
Washed it. Changed an indicator bulb. Realised that a line in the rear windscreen heater has packed up [emoji849]
massiveCoRbyn
  Several
Nothing this morning, but going to Pipecraft in Basildon this afternoon to have the middle silencer removed from the Megane.
