Mystery of the acoustic valve
Tin.tin
  Clio 182
Evening gents
Have been thinking about to the curious mystery of the acoustic valve. Many different opinions on what it actually does, each telling their own tale of what power it truly holds.
Since getting my 182 almost 3 years ago, I've had this issue where every time I start the car after letting it sit overnight, power feels restricted for maybe 2/3 minutes. Typically let it sit before driving. Took the car in to my local specialist and he couldn't work it out. Scoured the ancient scrolls & found people with a similar issue but no answer - ultimately put it down to the car being quirky. Or having a restrictor that stops engine revving too high when cold, I tell myself this version as it helps me get to sleep.
Accepted this and learnt to live it as it didn't bother me too much. Car when I bought it had some missing bits which I'd be re fitting. Got an acoustic valve off Ebay, fitted it and to my surprise, the cold start issue had disappeared. For a good 3/4 days the mystery was solved - sadly didn't last long.
Now just wondering if AV could be related to this. Have read somewhere that valve is there to restrict noise which makes sense as its in the name 'acoustic' however, after my experience I can't help but wonder if there's more to it.
What's everyone's experience after fitting AV - any notable difference?
Cheers .
Mr Trailer Man
I've heard/read somewhere that it is used during the warming up cycle/cold start.
But I can't remember where I saw that.
When you say restricted power, how do you mean? They have a cold limiter in the 6500rpm range if that's what you mean...
Flob
The acoustic valves main purpose is when you have a wheelie bin and its not full and you're like - wow, I wish this was full so I could get as much value out of my extortionate council tax as possible then you remember that piece of s**t thing you tore out your Clio a few months before and it fits in the last little bit of bin space perfectly.
That is all it is good for.
Tin.tin
  Clio 182
You can put your foot down but it won't go past 20, Its almost what you get with the speed limiter feature. Can't quite remember what rpm limits at but definitely not as high 6500rpm for me (n)
Matt Cup
  Iceberg 172 Cup
Same for the carbon canister?
Flob
That not right at all.
My money is on a failing injector. My Clio had a failing injector for ages, when cold the car is in open loop so doesn't use the lambda sensor, when its warm it corrects for overly rich mixture using the lambda. So they run like s**t at cold, but better when warm.
Mine did this for ages before throwing an occasional EML, eventually it got bad enough that it was misfiring too.
Flob
Mr Trailer Man
Hmm there's something definitely not right there.
Acoustic valve or not, it shouldn't do that.
I've not seen that before 🤔
Tin.tin
  Clio 182
Tin.tin
  Clio 182
Didn’t think so but gotta get to sleep somehow so I’ve made up some good theories 😂
Due to go in to another specialist soon will see what he makes of it hopefully gets sorted.
Tin.tin
  Clio 182
80% injector, 10% vac leak, 10% some other fuel delivery issue.
Had new injectors in this year. Maybe vac leak or maybe fancy rev limiting warm up option you didn't get in yours lol will report back.
Flob
while they are crap from cold, its not normal to be struggling to go over 20mph lol
id be checking lambda sensor first.
If not injectors then yes, but the lambda does nothing on these after start, takes a few mins for closed loop to kick in.
More likely when the lambda closed loop kicks in it is fixing whatever's wrong.
Brigsy
  T.Turbo
This. Mine used to instantly sort itself out as soon as on closed loop, something daft like 1 notch up the temp gauge. Remap from a decent place will sort it.
Megane rs does exactly the same, think its retarded timing for faster warmup. All of mine have had it sorted when mapped, makes a mega difference on daily use.
Brigsy
  T.Turbo
From factory I believe the VVT is disabled from cold start, that's what Henk does with the RStuner, enables VVT from cold which I believe is why it makes them drive much better
Interesting that, still megane 2 rs doesnt have vvt and just as crap. Vvt is disabled until 50deg clt temps on my ecumaster, runs great in warmup however.
Flob
I believe they also r****d ignition timing a lot for higher EGT to get CAT up to temp which is probably why yours runs sweet even from cold Brigsy and also why some cars with an exhaust will pop and burble when cold.
karol_SVK
  PB172,XC70_2.5T
I guess engage the next gear and will do more than 20mph. I solved this by having a garage so far from the mainroad that the lamba gets up to temp;)
davo172
  TCR'd 172
12 grand for discs and pads FLOL!!
I paid less than that when I bought my 172 brand new in 2002🤣🤣
You can get them done anywhere and still keep your warranty its just another main dealer rip off!
Car looks epic.😎
