Spark plugs
  clio sport 200
After a little advice just removed theses from a friends car and as you can see the one from number 4 is black. What could cause this??
Thanks in advance
  PH2 172
I’m assuming a Triumph Spitfire doesn’t use the same spark plugs as a 1*2. But I could be wrong.
I was going to say Cortina, but then some smart arse would point out that these are 14mm, not 18mm with a taper seat.
