Manifold removal
  Liberty
Removing inlet to paint and I cant work out how to remove one last remaining pipe / sensor (sorry should know what it is for but I don't) at the rear. Sorry I cant be precise however I'm sure anyone that has done the job will know which one I'm talking about....hopefully.
Cheers Steve
Louis
I Love Ed Sheeran
Literally just removed mine. Presume it's the rubber one with the crimped hose?
Just put a screwdriver against the end of it and pull it. Should slide off
  Liberty
Thanks but it's the one with the elbow joint thats next to the crimped hose.
  Liberty
Thanks for the comments guys. As usual just needed to remove the training bra and give it a bit more force. Screwdriver to lever off !
Louis
I Love Ed Sheeran
I know which one you meant after having my mani off again. It's just the breather to the airbox iirc
  PH2 172
Vacuum take off for the carbon canister on a 182.
  PH2 172
It's the other one I think that's not on the upper inlet. The right angle on at the bottom? Or am I wrong
I assumed it was this one that was the subject of discussion.
