Q: ph1 silver dasch trim
  honda crx
hey, anyone can tell me if i can to remove silver colored surrounding of stereo?
i need to take to hydrographic but it looks like gona be hard :)
Rob
As Cat says, you cannot. Which is a ball ache because it gets a bit manky over time.
Best bet is to remove the dash and paint the bastardised thing whilst it’s out!
Coops Mk1
  Lots of Scrap...
you can........but its plastic welded into the dash so its a b*****d of a job to do neat enough to refit it
cat171
Quick bump,
The top of mine had got dirty after I'd had the AC sorted out, I couldn't clean it off and it annoyed me. I've 'de smegged it' by taking the coating off all round & it looks nice, apart from the bit above the vents :(
What have you guys done to sort it ? Have any of you successfully repainted the silver part ? How hard is it to get that part of the dash out ?
I want to restore it so it looks like new.
Rob
Quick bump,
Got any pics?
I'd consider using some solvent to get all the sticky off and just be left with silver, before you go mental and try to remove it all.
cat171
Got any pics?
Nah, but I can get some later.
I took all of the coating off just leaving the silver paint, which looks ok.. apart from the silver above the vents. I can't work out of it's deep 'smeg' or if the paint's worn away, I suspect the latter :(
cat171
Here @Rob
Got a couple of pics, it looks much better in real life than it does here. It's just the top bit above the vents that's rubbish :(
1409746
1409747
(yes that is the original tape deck lol!!)
