182 Gearbox leak
Clark87
Car  Clio 182
So I’ve finally got around to fitting gearbox and filled with gear oil came back to the car after a few days it’s leaking from the gear casing. Looks like from around the bolt area?
    294 KBViews: 0
Yes looks to be From the bolt area. Is the cover pretty easy to remove? Will I have to take the box out to do ?
It’s only had oil in for couple days it’s not moved an inch as it’s was engine out job new turbo conversion one in so didn’t fill till needed
