EngineDoes anyone know torque specs for conrod bolts and main cap bolts in clio 172 engine?
Best regards
Thanks, you are legend.Engine
- Big End Bearings: 20N·m then 40°
- Camshaft Cover: 12N·m
- Camshaft Carrier/Cap: 12N·m
- Clutch Cover to Flywheel: 20N·m
- Compressor Support Mounting Bolt: 62N·m ± 6N·m
- Compressor Mounting Bolt: 32N·m ± 3N·m
- Cylinder Head Bolts: 20N·m + (165° ± 6°)
- Cylinder Head Cover Bolts: 12N·m
- Engine Tie-Rod Bolt: 62N·m
- Flywheel Bolts: 55N·m
- Ignition Coil: 9N·m ± 1N·m
- Injector Support Bolts: 21N·m ± 2N·m
- Inlet Manifold Upper: 11N·m 2N·m
- Inlet Manifold Lower: 21N·m
- Knock Sensor: 20N·m
- Main Bearings: 20N·m then 62° ± 6°
- Oil Filter: 20N·m
- Oil Pump to Cylinder Block: 25N·m
- Oil Separator Bolts: 13N·m
- Spark Plugs: 25-30N·m
- Starter Mounting Bolt: 30N·m
- Subframe Mounting Bolts:
- Front: 62N·m
- Rear: 105N·m
- Sump Plug: 14N·m
- Sump Bolts: 8N·m then 12-15N·m
- Throttle Housing: 13N·m
your welcomeThanks, you are legend.
Best regards
Bolts are tighten first then released then tighten again to specific torque. So its going to be fine, at least i thinkhead bolt torque is wrong. needs to compress as it's an mls gasket.
these are the torque settings yourself and others have posted on the torque threaddon't release them, torque, leave for ten minutes, torque again and then final 180deg.
these are the torque settings yourself and others have posted on the torque thread@bloke
I stand correctedwhat thread have i posted it in?
I stand corrected
You said in post it wrong.
I send my deepest apologies
Someone should edit the threadIt's cool, got me paranoid I'd mistyped it and it was wrong!!
