suspension swap
GrahamS
Yes they will but you will need to swap the subframe, wishbones, hubs, driveshafts, and struts for sport items. I have a video on YouTube which shows you how.
GrahamS
shouldn't need to swap the subframe? just the rest.
The wishbone holes are further out on the sports I believe. I've actually never measured myself but had it confirmed to me by someone that did. Swapping to a sport subframe will also give you the hole and opportunity to run the 4th gearbox mount.
Martin_172
Na subframes are identical apart from the hole for the 4th mount, 30 seconds with a drill and they are identical, just finished the swap using the standard subframe
