182 manifold with 172 exhaust
RichValver
Car  Clio 16v/172 daily
What do I need altogether to get this to work. I have a ktec catback at the moment and have a 182 manifold to fit. Can I use a 182 cat or do I need to use a link pipe? I'd like to be able to switch out cat/decat and using a standard 182 cat would be easiest option. Also what happens with lambda's
Pics/details appreciated
Thanks 😊
You will need a piece to match up to the olive joint on the cat, or cut it off and weld on a sleeve joint.
