Exhaust heat sheild
RustyMojo
Bon Jovi Officianado
So my back box heat shield on my 182 is cabbaged/very Rotten and given I am working underneath the car currently it’s annoying me no end. So I spoke with Renault and they are no longer supplying!! I’m going to guess most of these heat shields are going to be past their best now. So finding a used one may be difficult! So what are the options? Has anyone made one out side some of the engine heat shield material such as this?
Any other suggestions?
Eddie555
  Q7 2018 & 172 Cup.
I know exactly what you mean about its a bit rotten under there.. Mine is looking dodgy in places and needs replacing.. Its a job i'm avoiding at the moment as i have plenty to do already.. What youve posted is what ill be using to replace mine so youre on the right path.. Ill just remove my old shields and use them as templates..
Sent from my SM-G977B using Tapatalk
RustyMojo
perfect, it looks simple enough to do and given it’s hidden largely by the exhaust and underneath the car, I can’t see me making too much of a hash of it! Noticed I don’t actually have a bad box heat shield. That must have been removed years ago. Not sure one is needed under the boot floor mind.
Eddie555
  Q7 2018 & 172 Cup.
The only thing im scared of is ive tried to remove some of the Torx head screws holding some parts of shields along the tunnel and they're pretty well seized.. I can see me under there quite a while drilling and re-taping them. Its not going to be an easy job..
RustyMojo
I have been so lucky! Mine were perfect! Hardly any grief at all... that said everything else had been welded in with rust so far! I’m just waiting for a delivery now so I can finish off the back end of the car floor pan, then I need a blaster/powder coater to reopen so I can get my rear beam reconditioned then I will move on to the middle section of the floor pan. Think I’ll replace all of the heat shields with my own custom versions to tidy things up a little. I am changing the exhaust anyway, so will drop it all out and make some templates.
RustyMojo
Well it runs to where the back box joins, but like I said over the fuel tank. No need to be pedantic! Self adhesive probably isn’t going to be great underneath the car. Think I’m going to make my own out of the stuff I linked earlier
Eddie555
  Q7 2018 & 172 Cup.
Where are you based?
I use these guys for all my powder coating.. Very reasonably priced and quick turn around, normally 48hrs..
