Whiteline drop links?
YorkshireKyle
Depends, is your car still on standard height droplinks and do they cause any issue?
I know on Polo's you have to run shorter droplinks on lowered cars as I quickly learnt with my sisters 6C. Whereas on my Megane running standardised droplinks are fine
Danith
  GTi 7.5 pp/Mx5 nd2
It's for the octavia.
Cars dropped 25 to 30mm, was gonna replace the fronts anyway.
Plastic drop links on rear of these too!
Are pricey but a guy is selling some used that have done 150 miles
JamesBryan
If it's lowered and the ARB is under tension, then adjustable links will make a difference.
You don't want any preload on the ARB ideally.
Need to set the length of the link when the car is at normal ride height.
Made a nice difference to turn in on my MR2 when I neutralized the ARB's via adjustable drop links. They must be set with the suspension loaded, needs to be done on a ramp really.
Danith
  GTi 7.5 pp/Mx5 nd2
Had a look and there are much cheaper options than the whiteline now. Will try some up front, ta.
Spring loaded suspension seem to do a couple of sets
