Where to put axle stands on the rear
04-182
Car  AB Clio 182
Hi, i use the frame rails at the front when i put my car on stands but where do i put them at the rear? I need to drop the rear axle so that i can change the springs but don't want to use the sills as they're not great.
Thanks in advance
Not a huge amount of options if you need to drop the beam, rear chassis rails are to high up for most axle stands.
Get some rubber pads for your axle stands, ones woth a slot cut in then. May help reduce damage
Thanks for the replies all. Much appreciated. Have ordered some pads for my stands. Thanks again.
Never had any problems putting them on the sills at the back. Never damaged them. Hardly any weight there anyway
Took me all of 3 mins to get the beam off and 2 of that was standing jacking the car up😂😂
