197 cams or GrpN timing?
Mine made 212bhp peak and nice flat torque curve (159lbft peak) with 197 cams with 8 degree advance on inlet cam (no idea what group n means, actual degrees is what you need to know) supporting mods of rs2 inlet (original version) 182 exhaust manifold and 197 fuel injectors
Chris @efi mapped it and it runs and drives beautifully on road or track
197 cams is intake cam advanced 7-8 deg
Group N is standard cams with intake advanced 7 deg and exhaust retarded 7 deg.
You lose a bit low end on Group N i believe.
Is the 7-8degree advance on the inlet cam manually set? or is that tuned for
