Cup alternator?
DomP182
  ph1 172, Arctic182
I'm looking for some clarification on this alternator, is it a cup version as the terminals foul the ac. hoses. If it is does anyone want a swap?
Coops Mk1
  Lots of Scrap...
The label should say ampage, 110 is standard think cup is 75 maybe. Plus standard is offset mounting points, cup is top and bottom
DomP182
  ph1 172, Arctic182
I cant make out the label its worn off, on my old one the terminals are rotated 180° from the position in this photo
JamesBryan
  Titanium 182
A Cup one won't fit the AC mounting positions.
There's loads of alternators about that have that connection on the wrong way...
MarcB
  Too Many
Cup Alternator is 75A
Part numbers are and the bottom is an exchange item.
JamesBryan
  Titanium 182
It fits the bottom mount but not the top mount by a out 5mm
I'm guessing you're fitting a Valeo unit?
As that's about the only one that's worth fitting unless you want to do it again in a week's time 😂
DomP182
  ph1 172, Arctic182
Yeah I'll use a valeo. I might try and find a good used one, £182 is more than I'd like to spend right now
DomP182
  ph1 172, Arctic182
Looking at it today I think it may be neither a cup or non cup alternator, I'll get some photos up for clarification
DomP182
  ph1 172, Arctic182
A13VL195 8200193100 comes up as a kangoo 110a alternator, is this of any use in th 1*2 world?
MarcB
  Too Many
First one is non exchange
Second one is exchange.
This is taken from a Clio 182 Trophy running A/C and it’s 110amp
MarcB
  Too Many
This is the OE part number for a 182 110amp alternator.
I have put part numbers above and both are Valeo and this one was taken off my car.
DomP182
  ph1 172, Arctic182
So is there a difference between 182 and 172 alternators?
I'm confused now, the main problem with the one I have is the power terminal is right up against the ac hose and the top mounting is over to the left by about 5mm. 'Family duties' have taken me away from playing with it for today😪
botfch
  Clio 182
In my flamer? Nope correct way with the two mounting lugs at the bottom, one at top
Yeah sorry I forgot the cup was fitted back to front.
I wonder if it’s possible to flip round the regulator so you can get the plugs in.
DomP182
  ph1 172, Arctic182
I have wondered if I could play around with the terminals except the top mounting point isnt quite right, it pulls on the bracket so either way it's a no go
