Clio epas full kit with controller & DCI rack
  clio 172
How much should I be paying for epas kit with the controller?
And also a dci rack ?
Is it worth putting dci rack or is the 182 ok ?
Thanks
Finch
VenomUK
  Clio 172
I too would like to know this. I opted for a dci rack and that was from eBay at £25 which I think is the going rate. The controller again on eBay looks to be around the £35-40 mark. I'm struggling to lock down an EPAS rack and ECU. seem to be about £80-£100 but when communicating with the breaker of what I want they never fill me with confidence that I'm going to get everything I ask for.
Mbeau
  Clio 172
I have a EPAS ECU for sale?
I recently sold a complete kit just needing the ebay controller to complete for £80. The 1.2, 1.4 and DCI Clios all have the same EPAS column and ECU.
VenomUK
  Clio 172
What have you got for sale? just the ECU or the column aswell?
Why are the controllers so expensive on here when they are £40 on eBay, what's the difference?
Mbeau
  Clio 172
Who sells controllers on here? Thought people just bought the kit off Ebay.
I only have a spare EPAS ECU for sale now with the correct plugs that have been cut from the loom @VenomUK
VenomUK
  Clio 172
These are what I’ve been linked too from here in the past.
Can you explain what each plug does please. Blue is the one that goes to the motor isn’t it. What does the black and the rectangle one do or used for?
VenomUK
  Clio 172
@ZachB That picture above of the ECU, could you tell me what each plug is for please? I'm guessing the blue blue is the cable that connects the ECU to the column motor?
Blue is from the motor, black is power from battery and ground, rectangle connects the column to the ecu and there is also a small power and ground. The instructions that come with the kit will tell you which colours do what and where to splice them. What wiring tools do you have?
In the non sports there is wiring from other areas going to the steering ecu that you dont use. You only need to think about the kit, 4 wires go from the plug into the box of tricks, then those 4 wires connect to the column. The 2 other wires are power and ground.
Mbeau
  Clio 172
Zach is probably best placed to answer your question. I have never fitted EPAS, just had the kit ready to fit on my track car, which I have now sold. It is my understanding that it is fairly straightforward to wire up. There are plenty on here that have done it.
@VenomUK You need to check if you have this wiring already in your loom, you can then source a non sport bulkhead loom which has the rest of the oem wiring, then you only have to splice the small wires from the kit to the column.
VenomUK
  Clio 172
@ZachB I think I understand. So what should I be asking the bloke at the breakers to keep connected?
Blue plug - shouldn't be cut and connected to the motor its blue sheath.
Black plug - just need a length of cable attached so that I can add on and run it to power and ground.
Rectangle - shouldn't be cut and should still be connected to the column?
Where is this small power and ground cable found and the kid you speak of is the one off of eBay/inferno?
The wire in your pic, where would I find these? My Clio is currenlty stock by the way.
I didnt see you'd quoted that post I made on the column from ebay sorry. The picture of the wiring Im holding and one other wire that I may have (I need to find it) combined with the column and ecu with the ebay kit you posted is what you need. I can send you the the power and earth wires (pictured) so you dont have do any crimping, I have spare 50/60a fuses (forgot which they are) as well.
VenomUK
  Clio 172
I would appreciate that. I have purchased one the racks from the eBay posting you posted and just asked him to keep the wires attached as I wasn't sure what it was I needed. If you message me I will sort out some postage and some extra for your troubles.
No problem but you need to check first if you have that wiring! Because my 182 loom didnt but 172 cup loom I had did
It will be near where the steering ecu would be to the right of the column if so.
VenomUK
  Clio 172
I will check and let you know. Mines a non cup 172 so not holding my breath
Bump!!!
4 years on and although I've been toying with the idea for many years now and not taken the plunge, it's now time too as I'm having power steering leaking from my rack and sensor in the block so want to delete the standard setup and replace with EPAS.
Can't keep leaving MarioKart Rainbow Roads everywhere I park!
Can anyone help me in sourcing the needed parts please? Including a list and maybe a how too? I have a mate who's done a few conversions to his own so I'm OK with having it fitted but want to make sure I get everything needed.
2003 Clio 172. Need everything to do the conversion.
What's the going rate on parts?
Found a controller on ebay for about £40 but struggling to find the rack, found 1 but wont courier. I'll scab through this thread to see what else I'm needing.
Pic of my J.A.R.V.I.S.172
