Steering wheel rattle when slightly moved
  Clio 172 2002
Hi, I was wondering if any of you guys knew what could cause this rattle
Thank you.
Louis
I Love Ed Sheeran
Pull off the top plastic cowling and see if it still happens. If it does disconnect the battery and pull out the airbag then check the nut inside is tight
Bankrupt_drunk
  Clio 172
There's a big torx head screw under the airbag. I suspect that's loose.
It looks like this.
Bankrupt_drunk
  Clio 172
Disconnect the battery, then press in the brake pedal for 20 seconds to make sure it's fully drained.
This guide shows how to remove the airbag.
Bankrupt_drunk
  Clio 172
And obviously, make sure you've got a big torx head socket before you start (I think it's a T50). If it's not the screw then it may be the column bearing.
