Lambda fault RS Tuner
RichValver
Car  Clio 16v/172 daily
Anyone know what they are looking at here?
The fault is popping the engine management light up, I can switch it off but will come back on after a while.
Is it a problem with the sensor ir wiring or just the fact I'm using a sportcat that it's coming up?
Looks like rear wiring is fucked, is the sensor new? Front should be constant voltage and rear tracking
Probably just the sensor that's dead, should be between 0.1-0.9v.
Also, your battery voltage is low too, 11.6v with the engine running isn't enough ;)
Iv not been using the car at all really, where am I looking for those figures. Noob here 😂
Iv ordered a replacement lambda, can I test it by just plugging it in without fitting it I to the Exhaust? Just to see if its the wiring at fault?
Replaced the sensor, hopefully this fixes the issue. Both sensors seem to be around the same figure now
