Nice one , think I’ll message for one of those washers soon if they’re still going?Also a high tensile 10.9 bolt from memory so just bear that in mind if you go aftermarket replacement![]()
Cheers will try cleaning if no good I’ll start searching!They’re an M10 hex bolt - 45 mm in length. You’ll need a heavy duty washer mind, otherwise they’ll bend when you torque them down. Here’s the part number 7703019198 but NLA I’m afraid.
Yeah got a few here still!Nice one , think I’ll message for one of those washers soon if they’re still going?
...a phrase that's increasingly familiar on here, unfortunately.They’re an M10 hex bolt - 45 mm in length. You’ll need a heavy duty washer mind, otherwise they’ll bend when you torque them down. Here’s the part number 7703019198 but NLA I’m afraid.
Maybe a bit daft but would I be correct in thinking I can take the 4 bolts out without engine falling ? With jack under of corse but don’t want to rely on jack for an extended period.Take them out and stick them in a tub of citric acid mixed with water. Will be clean of rust in a day or so, paint and refit.
Can confirm this works cheers ! Used oil instead of paint hopefully does the trick.Take them out and stick them in a tub of citric acid mixed with water. Will be clean of rust in a day or so, paint and refit.
