Clio 2 1.5 dci excessive smoke
Car  Clio 2 1.5dci
Hi everyone, I recently got a 2005 clio 2 1.5 dci 65hp K9KA7 from a friend. The car starts and runs just fine with the exception of smoking like crazy. At idle there is zero smoke, when you rev it fast in neutral the car will smoke black and when you hold the high rpm, the smoke is grey to white. Car didn't show any errors on the dash and the engine power is still just fine. Also EGR was replaced not too long ago. Oil consumption is also a bit high but not too excessive.
Any ideas on what to check? I first suspected the injectors, so I did a leak-off test and after a few minutes of idling and revving the car I got the following values in grams of diesel per injector: 50, 51, 37, 75. Is there something else I should check before going to the junkyard to get spare injectors?
Thanks in advance for all the help 🙂
