Coilovers options for 172 cup
Darryl_1983
  RB 182 Cup
Looking to freshen up the suspension on my Cup, and with the cost of dampers these days I'm looking at potentially moving to Coilovers, so I'm reviewing options at the cheaper end of the spectrum (approx £750-£1k).
Initially, I just figured I'd throw a set of Bilstein B14's on it, as the car will be 99.9% road driven, and used alongside my Z4 for daily duties. The last thing I'd want is a super stiff track setup.
I understand that BC Racing is another option, and that the spring rates and damping can be changed to suit mainly road driving, along with the adjustability to stiffen and soften the damping once installed on the car, for when taking to track days. Would these be a better option and worth the extra £250 over the Bilsteins? Also, what spring rates would people recommend if moving away from the standard rates supplied?
Are they're any other decent options?
Thanks
Brigsy
  T.Turbo
Stick to the bilstein b14, bang on for road use.
Damping adjustment on bc is sketchy at best. Usually bouncy/soft or hard as fcuk from experience.
the_baron_von_richthofen
  2003 Clio 172 Cup
I know this isnt what you asked, but there really isnt much wrong with Cup dampers and some lowering springs (grams or Cooksport).
They are very nice to use on track too.
That said, I think the BC's are just out of your budget and like Brigsy says, the B14's have a great reputation for being good on the road.
plenty
I haven't tried B14s but I am very happy with BC DS series on the Clio platform (and fwiw BC BR series on the E85 Z4 platform).
Having experimented with various spring-rate combinations I've settled on 7F/5R as being ideal (for me) on the road. Which happens to be exactly what Bilstein offers with the Clio B14 kit. BC provides 4.5F/6R by default which is closer to OEM, but this can be customised.
For track you ideally want stiffer at the rear. Easily done simply by fitting heavier springs (dampers valved for 5 kgs rear springs should accommodate up to 8-9 kgs springs without problem).
Note that BC offer different variants, all but one of which include solid top mounts whereas the B14s don't come with top mounts.
Jamie86
  RS175,595,205gti,172
How much are cup dampers and some Eibachs these days? Still one of the best setups for a road car with a rear arb imo
16v_paddy
  Valvers & 172 Cup
A set of Eibachs are about £275 but the shocks are unavailable from anywhere atm except 182 Cup items & they're the best part of £180 each
I need new shocks for my daily 172 but with what's available right now and the cost, it's not much of a jump in price to coilovers. I'm seriously considering getting some B14's on my 172 Cup and fitting the not very old stuff onto my daily
npt
  BMW 320d- 172 cup
Bilstein is all you'll need, I ordered mine direct from Germany years ago which was much cheaper, I guess you still can, I couldn't find the link I used though 🫣
Darryl_1983
  RB 182 Cup
I actually think that BC’s are better than b14’s
This for Road use or track, or both? I've seen some complaints about the Bilsteins being too soft on track, but also a thread or two about them also being too stiff. I know the setup and feel are subjective, so just gathering some opinions at this stage before committing.
I've not seen too many bad reviews of the BC yet, though i guess the issue with these is that spring rates can be vastly different between two sets.
I've had 11 mk2 RS Clio's now, and I've always fancied switching to coilovers, so it's more of a want than a need. But as mentioned, it's not such a big gap between going cup dampers and lowering springs to decent coilovers these days.
As with all car related purchases, the budget is loose. Though I need to consider that I've just sold a perfectly suitable 330d E91, to daily a 172 cup. I may regret that over the next few months. So don't want to overspend, and be massively out of pocket if I decide to go back down the sensible route.
My Z4 definitely needs to be a little stiffer, but I think I'm going to switch to a shorter ratio diff I've got in the garage to trial before installing a blackline diff (may go shorter). At least that's the plan. It's currently on Eibach springs, but seems a little too soft when spiritedly driving around Lincolnshire recently.
I assume you went with custom spring rates with the BC's , did you trial many other spring rates? Looking at KAM Racing website, it seems like the typical options are as you noted as standard, then a variety of track setup ratings.
Noted regarding the top mounts, i was actually thinking about going solid top mounts too, just because the standard Renault setup seems crap. I've just replaced mine for a new set of SNR items hoping this would cure my knocking, it definitely helped, but still seems to be knowing. and i can't fully rule out the top mounts still.
I guess the other option is to fit Koni dampers from Autodoc at a little over £500, plus the springs.
I'm leaning towards the Bilsteins currently, just as they're a fit and forget setup, along with being cheaper than the BC's
Advikaz
Both road and track.
The joy with the BC’s is you can wind on the preload and stiffen them up.
Darryl_1983
  RB 182 Cup
I've still not pulled the trigger on any of these, as I'm going back and forth.
I think either way, I want to upgrade the top mounts to fixed. So, pricing becomes pretty much the same for the two options.
Do you know what spring ratings you're using?
Looking at spring rates for lowering springs, Kam Racing notes that the Grams lowering springs are 3.57kg/mm (F) and 5.8kg/mm (R). So I'm thinking that the default BC option of 4.5kg (F) & 6kg (R), would actually be a good starting point. I'm not sure how this would translate on the road with the damping and adjustment available, but I'd guess slightly stiffer than running lowering springs.
Advikaz
I’ll check mate
clio_cup
  172 Cup
what did you end up going with? After some coil overs for my cup, bilsteins are the easy option but worried they may be too soft for the odd track day I’ll be doing.
RallyXmad
  Cobra'd 172 Cup
I work with race car suspension for a living and I'd recommend going with a good 'regular' shock absorber over a cheap coilover.
If you do want a £1000 coilover then from what I've worked with the BC works well for the money. Don't expect coilovers to be more reliable than a regular shock doing road miles though
Darryl_1983
  RB 182 Cup
I've still not pulled the trigger to be honest. But I have now fitted some solid top mounts, and I've also been working through the front end bushes and ball joints to freshen everything up, and it feels better, along with getting rid of a knocking noise I was chasing.
I'm 99% set on the Bilsteins, but will likely leave it for a while now, as I've got some other things at home that are going to eat up my savings for the next few months.
I guess you need to decide whether you want track or road to be the priority with your setup. I've done track days with just lowering springs and AD08R tyres in the past, and they were fine. Bilsteins B14 are stiffer than lowering springs by quite a bit, so I can't imagine there being a big issue unless you're going pretty hardcore and running more aggressive tyres and brakes, etc.
BC Racing are probably the better option if track setup is the priority though, as you can opt for custom stiffer springs and then adjust the damping to suit track or road use. I'd be careful going too stiff with the springs if you intended on driving the car on the road regularly though.
