Clio 3 1.2 TCe 101hp (p0300 code)
Car  Clio III 1.2 Tce 100
Hi everyone, I'm having a problem with my Renault Clio 3 (petrol engine). When the car gets warm the engine starts to vibrate and idle roughly, and the check engine light starts blinking. I scanned it with OBD2 and got code P0300 (random/multiple misfires). I also captured live data and a freeze frame screenshot while the light was blinking, so I know it reflects the issue in real time. Here's what I've already replaced:
• Spark plugs
• Ignition coil pack and leads
• Engine oil and filters
Cleaned the fuel injectors
New timing kit
• Valve clearance The problem still comes back after warming up. Anyone experienced something similar or know what to check next? Thanks in advance! (Screenshots attached)
Did you fit genuine TCE spark plugs?
Also give your TDC sensor a clean.
yes but is it the correct plugs? 1.2 16v and 1.2 16v TCE are different.
once plugs and coil pack/leads are ruled out id be looking at injectors, thermostat and upstream lambda
ILKAR7A7 spark plugs,injectors are cleaned ultrasonicly and tested.
Thermostat shows right temperature.
1.2TCe does have one pre catalyst and one post catalyst O2 sensor?
Here is a short video of OBD diagnosis, Ive notice that the oxygen sensor`s voltage drops under 0.1V when driving and Intake manifold pressure drops to 2/3 Psi.
Are they supposed to be like this?
  • screen-20250630-194639.mp4~2.mp4
    35.6 MB
