Clio 172 Loud knocking on Track / not on road
Dan1987wales
Car  Clio 172
Evening all
Wondering if any of you guys could help with a frustrating issue which meant a pretty pointless track day at Donnington on Sunday 🙄
My 172 has just had all new Gaz coilovers, driveshafts, alignment, 200 cell cat, rear brakes (basically a load of work to sort it out for track work)
Also got an MOT which could point to the problem maybe as well….
The problem I have is that when cornering on track to the right I get a really harsh knocking noise on the front left side - it’s really quite bad when leaning on that wheel and undriveable on track.
It doesn’t do it on the road, only on track currently as it needs some pretty harsh cornering….
My garage thought possible driveshaft issues as the wheel bearing seemed ok - new driveshafts and it’s still doing it.
The MOT advisory’s state play in steering rack inner joints on both sides - could it be this?
If I Jack the wheel up there does feel like play in the 3 & 9 horizontal position, none at 12 & 6.
No real noise or drone like a wheel bearing & it doesn’t seem to matter if I’m on the power or not - as soon as I turn in it knocks away really bad. It should be obviously surely as it knocks so bad, but I’m no mechanic, just a weekend amateur at best.
Any thoughts would be massively appreciated! Pic at Donny in the car park where it spent most of the day with me sulking…
How much negative camber? At a guess driveshaft cvs bottoming out under suspension compression. Quite common on the clios.
For a quick test with car sat as normal on floor, buzz the driveshaft nut undone and check the cv plunge, should be able to push the shaft in 10mm or so.
If plunge is less than 10mm then you might be able to sort it by loosening off engine mounts and moving engine over a bit.
Thanks for this Brigsy - it’s funny how you don’t know what you don’t know!
The car is bloody low at the front and is running 2.2 degrees negative camber which maybe explains it….
I’ve since done some Googling and this seems to be a thing / makes sense.
Sorry, in real layman’s terms I undo the driveshaft nut and then I should be able to push the drive shaft in by 10mm - do I just literally push the end of the driveshaft with a screwdriver (or alike) and it should move back in the hub? Or do I grab the driveshaft at the back and pull it?
Apologies for the basic questions!
So it seems like I have 3 options if this is the problem?:
Move engine over a bit to drivers side
Raise ride height
Reduce camber
Cheers!
I echo the above theory and it would make sense that this only happens when you turn right as the left driveshaft is shorter than the one on the right.
Thanks - I’m definitely thinking it’s this now as well. Will investigate further…
Went into the garage tonight & she’s done a coolant wee on the floor as well now 🙄
This car is testing me at the moment!
remember the car and explains why i didn't see it out a lot on sunday. I got paranoid (nothing new there) with some vibrations just before lunch. Turned out just to be a lot of pickup on the inside of tyre.
Brigsy sounds like he's boxed your issue off
It’s been a minute / hoping to resurrect this thread - life & work has got in the way of this….
Checked the plunge on the passenger driveshaft and there was very little compared to the drivers side
I’ve whipped out the driveshaft today and it measures 650mm in length - I reckon I need a 640mm one to stop the knocking….
Does anyone where I can buy a 172 driveshaft thats shorter? Is it a bespoke jobby, any other models that will fit?
Many thanks in advance! 👍🏻
Sorry I forgot to mention that I’ve tried this, got maybe 7-10mm maybe, better but still didn’t cure it
After scouring eBay today I’ve found a 640mm LOBRO one from Lithuania
I’ll report back when it’s on to hopefully close this thread out with a resolution 🤞
Knocking noise fixed!!
Shorter drive shaft fixed the issue - I’d narrowed it down to pretty much knowing this would sort it and it has thank god!
For anyone having the same issue I bought a 640mm driveshaft on eBay from Lithuania, brand was LOBRO. A bit difficult to find & took some searching on eBay - this is the one:
I’ve done some very technical testing by loading weight plates into the passenger seat and chucked into a downhill left hander by my house that I know used to make the noise - all knocking gone!
Job done - track days now being booked 😀
Thanks for all the advice everyone!
Just found this thread, I've has a similar issue on the LH front side of my clio. Can't find anything loose, track rods and wishbones are all fairly new, driveshaft also OK. I'll have a look at the driveshaft position...
If it’s lowered or/and has a bit of negative camber I think this will be the issue mate 👍🏻
Thread bump if helps anyone out but Had this on my kangoo turned out to have a ph1 subframe fitted so track was narrower swapped to ph2 and sorted it as said it was shaft bottoming out on ns 👍🏻
