Subframe removal
16V F7R
  Clio 16V
I am going to tackle this job for the first time with my Valver. I want to remove the front subframe leaving the engine in.
Can people list me the do’s and don’ts and the correct order in which I should disconnect whats required to remove it.
The more tips and experience you can share the better please. The Front bumper, bonnet, head lights are all off. Rad is ready to come out, ball joints loosened off ready to be pried out. I’m on to the important bit now and I don’t want to screw anything up with my lack of experience.
16V F7R
  Clio 16V
Any help would be much appreciated, I know this is basic stuff for a lot of you but I am a novice and don’t want to screw anything up. It appears that I need to-
Remove my exhaust as I cannot disconnect from a cat because it has been removed and a pipe welded straight through.
Undo the back gearbox mount. Is that as simple as just undo the bolts remove one and move it out the way?
Remove the gear selector bar, what’s the best way to do this? Have the gearbox engaged into 1st and then remove the bar altogether?
One of my anti roll bar bolts keeps is just spinning around on the wishbone mount, the other one loosened fine, you cannot grip it from the top, does that mean it needs to just be cut off now?
More stupid questions will come, I would appreciate any advice.
16V F7R
  Clio 16V
Images of exhaust and mount and the only bolt causing me an issue right now.
RichValver
  Clio 16v/172 daily
Right, with the selector remove it at the pivot point so that you won't have to f**k about adjusting it again to get the gears. Might be a rubber boot around it
You will need to remove the driveshaft to drop the downpipe too
The captive nuts on the rear of the subframe will be a right b**ch as they will more than likely be siezed so will need to get a spanner in there
I would just cut those drop links as they need replacing. A set of nut splitters are always handy to have, can just split the nut if you don't have access to something to cut the drop links with
There will be pas pipes attached to the subframe, on the pass side somewhere. Will need to decide if you are dropping the rack with the subframe? You will need to remove the bolt holding it to the column, is a bit trick and there is a boot covering it. diconnect the pipes to the pas bottle and pump
16V F7R
  Clio 16V
Great advice on the selector thanks. 👍
I was hoping this could be done without removing any driveshafts damn!
I have made them move but my god I don’t see how I’m going to get a spanner in there at all, or will it become accessible once the exhaust is out of the way?
Thanks again, I will cut that now as don’t have nut splitters yet. Can the drop links and the track rod ends just be wacked out with a hammer than or shall I do that after I have removed the ball joints from the hub to release tension? Also what about this dog bone gear box mount?
There will be pas pipes attached to the subframe, on the pass side somewhere. Will need to decide if you are dropping the rack with the subframe? You will need to remove the bolt holding it to the column, is a bit trick and there is a boot covering it. diconnect the pipes to the pas bottle and pump.
Yes I need to consider what I am doing when I get to that bit.
Massive thanks for you help 👊
16V F7R
  Clio 16V
Ok exhaust is nearly out. Is there a special way to take this sensor out without me doing damage? Is it just a 22mm spanner and more WD40 or am I wrong?
RichValver
  Clio 16v/172 daily
You could also just drop the hubs/wishbones and even the shocks with the subframe then remove the bits after. Just remove the calipers from the hubs
The dog bone mount is just 2 bolts? Remove one or the other doesn't really matter which
Yarp
  182 Turbo, E46 M3
That’s how I do it.
Calipers off; undo the top mounts or shocks depending on what mood I’m in; undo the column bolt; dogbone off and then drop the lot as a oner.
Just don’t forget to buy your replacement subframe bolts from me 🤣
16V F7R
  Clio 16V
Nice one chaps. I really appreciate your help.. Ok ready for more s**t questions -
Thanks for clearing up that I can just undo the dog bone and there no tension to worry about.
Thanks for clearing up that I can just unplug the sensor and leave it in, silly me (Inexperience).
I ideally wanted to leave all the brakes, suspension and drive shafts alone for now and not get too overwhelmed. Is it still possible to do it without removing all this?
My suspension and drive shafts would keep all my hubs in place and safe for now is my thinking.
The sub frame bolt next to the fuel lines looks impossible to get a grip on the inner nut, is it a captive one anyway? How am I going to cut those off If they don’t come off?
I will defo have your subframe bolts please Yarp. Do you sell any other bolts? I’m going to refresh a lot.
The gear selector shaft removal from the gearbox end, i don’t want to rip or damage the rubber boot over it and I can seem to get it off without damaging it. I have seen them where they have to be cable tied. Shall I leave the gear stick in neutral to do this and do I need to remove it from the gear stick end as well so I don’t risk damaging it as the frame lowers down?
Thanks again everyone, I’m reasonably pleased with what I got done today, another day at it and hopefully it will be off and then onto the refurbishing phase which I plan to get carried away with a bit.
Yarp
  182 Turbo, E46 M3
If you want to leave all the brakes etc then you can either remove the wishbones or undo the bottom ball joints.
The wishbones sometimes aren’t the easiest things to get off so ball joints may be easier. If you look on the pic I shared above you can see they bolt onto the wishbone rather than pressed in so you can unbolt them and leave all the hubs/suspension etc in situ. If you’re removing the steering rack from the subframe then you can leave the track rod ends bolted up. If the rack is coming with it then you’ll need to undo the track rod ends from the hub. They need pressure applied from underneath to stop the bolt spinning. I normally just stick a jack under there.
The original subframe mounts use captive nuts and they will have dissolved so will spin. There are cut outs in the chassis that you can use to get a spanner in. It’s either 16 or 18mm, can’t remember which now!
16V F7R
  Clio 16V
This is great advice cheers! I have undone the track rod ends bolts but couldn’t get the track rod end out of the hub, even after I lifted the hub slightly with the jack. God I spend so much time f**king about with stuff where an experienced mechanic just smashes this out for fun! I get afraid to hit stuff hard enough or worry about if any load is on annything and I damage something or myself😂! I decided that removing the ball joints from the hub first would be best to release the stiffness of the track rod ends joints but I only have a 16mm socket (the other crap old one I had rounded) and I don’t have a 16mm spanner so couldn’t continue with removing the ball joints today. Plus I am going to get a ball joints separator. I will get the tools this week though and then -
Remove ball joints from the hub
Remove track rod ends from the hub
Remove dog bone
Remove gear linkage
Drain and disconnect the power steering fluid and pipes so the steering rack can come out (I am putting new track rod ends on so yes got to come out)
Finally remove the rad
Undo the 4 subframe bolts and lower it
Then tea and biscuits
Speedo Gonzales
Why didn't you just unbolt the track rods from the hubs, take the 4 bolts off of the balljoints and then take the bolt out of the rack and column?
You could have left the shafts and hubs in the car
It takes me about 30 mins to get the subframe dropped out of my car now. It's a terrible curse to have knowing exactly which bolts to take out to make it quick
16V F7R
  Clio 16V
A up Krarl, yes I’m leaving the shafts and hubs on 👍
I’ve still got to do what’s in my list in the last post though? Shouldn’t take long to be fair if the bolts aren’t seized too bad…
Speedo Gonzales
Ah sorry, didn't realise it was Steve being a special t**t and dropping the hubs and shafts. It all depends if you've got PAS or if you've looped your steering rack/got a manual rack
If you've got a proper blokes rack with no stupid hoses it's a piece of piss
  • 2 bolts out the balljoints each side
  • Track rod ends disconnected at hubs
  • Subframe supports off
  • Cable tie rad pack up
  • Dogbone off
  • Lower gearbox nut off
  • Rack pinch bolt out
  • Lower rad hose p clip off
  • Subframe support bars that connect to lower arms loosened and disconnected on car side
  • If you've got PAS dump all of the oil and disconnect the hoses
  • Support subframe with jack and wood lengthways
  • 4 subframe bolts out, hold the nuts with a spanner after you've snapped away the retainers
  • Drop subframe
My car is missing quite a lot of stuff compared to a standard car. But I've stripped enough Clios to realise there's not a whole lot that bolts to the subframe anyway
16V F7R
  Clio 16V
This is great info mate nice one.
Not sure what these are though-
Also how easy is it to disconnect the gear linkage the best way to not have to f**k about setting it up again afterwards, had a fun stint once in my 5 resetting the gear linkage but it was quite simple. I never removed it from the gearbox though.
16v_paddy
  Valvers & 172 Cup
Those are the 2 bars that 1 end attaches to the wishbones and the other to the chassis leg, just look at where the wishbone bolts go & you'll see the bar
As for the gear linkage, follow it to it's very end inside the rubber boot & undo it from there, don't touch the clamp part of it, that's what causes the hassle you had with your R5
16v_paddy
  Valvers & 172 Cup
Number 20 in the pic, that's where you undo it from, the bit circled in red is the spacer bush - don't lose that bit
16V F7R
  Clio 16V
Cheers Paddy, I thought he already mentioned those bars further up his list when he said subframe supports so I thought he meant something else 👍
I’ll man handle the rubber boot off and do as you’ve mentioned, many thanks 👍👍
Speedo Gonzales
Yeah undo the 13mm nut on the selector arm
DO NOT disconnect it at the slip joint if you value your sanity 🤣
And when you're dropping the subframe don't clag the weight of the subframe on the shifter rod. It will bend, they're made of cheese
Yarp
  182 Turbo, E46 M3
This is absolutely the best advice that any human can ever give another human. What an absolute shithouse those selectors are to re-align 🤣
And yup, the only reason I took the r****d approach was the box and engine were coming out so made no difference leaving the shafts in. Undoing the ball joints is the best option.
16V F7R
  Clio 16V
When I remove the 13mm nut on the gear selector arm, shall I have it in neutral position or in a gear and if so what gear?
Just the dog bone and the 4 subframe bolts and rad to remove now. I have started looking at parts to refresh. Is there a good aftermarket Ali rad I can still get? I know I don’t need one but I prefer them to standard rads. I want a new fan as well.
Also are these parts all correct below, eBay says they are for a 1.8 16v but id rather trust you lot than ebay.
ebay item numbers-
304624991670 drop links
220494058911 wishbones with ball joints set
381988345536 track rod end
162416298218 track rod end
And one more question, is there anything I need to know draining, disconnecting and eventually refilling the power steering fluid or just disconnect at the lowest point let it bleed and eventually fill it back up and there is no where to bleed air like coolant?
Louis
I Love Ed Sheeran
ebay item numbers-
It doesn't really matter what gear, you can move it manually after. Neutral is probably easiest though
16V F7R
  Clio 16V
s**t that is a lot of pipes going into this power steering pump. Am I disconnecting all these awkwardly with a spanner and then I can disconnect the steering rack bolt? I can drop this frame then.
16v_paddy
  Valvers & 172 Cup
No need to touch any of those, on the bendy joint at the bottom of the steering column, on 1 side of it is a 13mm nut, undo that, pop the bolt out and it's disconnected from the rack
16v_paddy
  Valvers & 172 Cup
On the far right of this pic is where the column connects to and the whole lot drops down as in the pic above it
16V F7R
  Clio 16V
Thanks for your help. So am I disconnecting a 13 mm nut from the shaft I have circled in green? Where’s the fluid going to drain from? Sorry if this sounds stupid but I have never done this before.
16V F7R
  Clio 16V
This looks like the answer to how I dump the fluid. Is that right?
16v_paddy
  Valvers & 172 Cup
The pipe circled in red goes to the power steering fluid reservoir and the 1 in green connects to the pump
The nut & bolt that connects the column & rack looks like this and it goes on the shaft you circled in green
16V F7R
  Clio 16V
So I need to disconnect from the pump at the front of the subframe and this in the pic. Thanks for explaining the rack bolt 👍
16v_paddy
  Valvers & 172 Cup
Yep (y)
Unfortunately getting the fluid out is going to piss out all over the place & make a mess no matter what you do so use some cardboard & plenty of rags to soak up the worst of it
16V F7R
  Clio 16V
Legendary cheers, I’m going to grab an hour or two at it again tomorrow. Thanks for your help mate 👍
16V F7R
  Clio 16V
Ok so a typical non productive hour again from me today. How do I detach this power steering pipe. Mine looks a bit different and is routed in between the front of the engine in between the radiator fan and the engine and there is hard piping around the gearbox and again above the rack. Either way, how do I disconnect these things? Also is it the jubilee style clip type what I need to disconnect from the the reservoir that goes down to the rack, at the rack end see what I have circled in the pic. Also do I need special pliers to get that clip off? And which section of the flexi pipe do I need to disconnect and how do I disconnect them? They don’t appear to have a spanner fitment?
16V F7R
  Clio 16V
I found the coupler behind the top of the rad to disconnect the power steering. I could not figure the removal of these weird jubilee clips but I managed to tease it off the rack and catch all the fluid coming out on the actual rack end.
I am hoping I am not going to have to take the driveshafts off with the subframe coming down with all these hard pipes for the power steering. Hopefully I will be able to bend it around the near side driveshaft.
For the column rack bolt. Am I best to get this 13mm nut off the rack from the inside of the car, it is a bloody nightmare to get to with that rubber boot obstructing the view of anything. Plus there is no space, I don’t know how I will get that bolt back in, if I get it out!
Taking me bloody ages this 🤦‍♂️and this is just dismantling and not building back up!
16V F7R
  Clio 16V
Got that steering rack bolt out, went in through the side with arm through the wheel arch and also could get the bolt out the back inbetween the back of the subframe and the anti roll bar. That will be the best place to slide it back in. I am not looking forward to getting that back in.
Anyway I am just having to drop the subframe now, thank f**k. Well finally remove that linkage bolt and then carefully do it. However I have that one subframe bolt and the back that is not loosening and the nut is not being gripped by my 19mm spanner. The other side at the back is coming off and lowering the subframe slightly. So I think I am good with that one.
So what do you do when this bolt won’t come out? I don’t know if it is my spanner that isn’t getting the angle to grip the nut right or where do you cut it or do you get a long cold chisel and try and crack off the nut in the subframe to break it off? That nut and the bolt are starting to ‘dissolve’ as you say.
Thanks again to everyone who has helped with this.
16v_paddy
  Valvers & 172 Cup
Worse case scenario is you have to get jiggy with a grinder and just chop the bolt
