Doing driveshafts, dampers and springs- what else?
Polynesian
  Alpina B3, 172, 325i
Basically that. I’m about to put fresh cup dampers on my 172 Cup, cooksport springs and both driveshafts. What else is an obvious job/change to do on a weary Cup while these bits are being done?
Will change the gearbox oil, obvs. Any bushes? Thanks.
Polynesian
Depends how far you want to go. You could refresh the whole front end if you have the time/money.
Yeah, it quite quickly becomes that, doesn’t it. I’m working on two other cars at the same time so it may be this for now and then a refurbed subframe, wishbones etc etc in a year or two.
Brigsy
  T.Turbo
Suspension top mounts. Inner tie rods and track rod ends, as you will need the geo doing and fresh steering parts usually make a massive difference.
Personally id get the crowbar on the bushes and balljoints to check if they are good or not.
ex-Chinese Dave
Changing the ball joints on wishbones made a huge difference to mine for a small cost. If you have the chance you can a change all the bushes, too. I didn’t change them as they seemed fine. You could also do all four engine mounts.
