vibrations and tremors at idle clio 182
Car  Clio 182 cup
Good afternoon, I'd like to share my experience with my Clio 182.
I've had vibrations at idle for a long time (if you open the hood and look at the engine very carefully, you'll notice it wobbles a little; it's nothing extreme, but it's quite noticeable inside the car).
I've replaced quite a few parts due to time and mileage: original NGK spark plugs, a Beru coil, new spark plug wires (they're not original, Beru, or NGK... I don't remember the brand... but it wasn't one of the major brands because at the time the parts supplier didn't have anything else in stock... although it already had the problem before). I also replaced four new original injectors, the engine mounts are two years old or less, and the timing belt was replaced about a year and a half ago.
I've checked for vacuum leaks and can't seem to find any (within the limitations of doing it myself), although, for example, the intake manifold gasket is the original one.
I'll leave it with the mechanic next week. Let's see if I can find the fault, but as I mentioned, it's really getting on my nerves...
By the way, there's no malfunction indicator light on. I ran a diagnostic (with an OBD scanner and a mobile app) and the data and readings are completely normal, from the lambda sensor and the MAP sensor to the temperatures, etc.
I should also mention that there's no jerking while driving, no lack of power, no misfiring, I don't notice anything strange, fuel consumption is also fine, but at idle you can feel those vibrations.
If anyone has experienced something similar and can offer some help, it would be greatly appreciated. Many thanks in advance to everyone.
Here's a video so you can see it (the gear shift lever already has some play, so it makes everything even worse).
Could faulty injectors be the cause of the rough idle?
I replaced them a year and a half ago, but honestly, I'm not ruling anything out. Looking at the wiring for injector number 1 from the front, I had to clean it up a long time ago because the wire was frayed from being bent to connect to the injector itself...
I don't know if the problems could be coming from there.
But it only happens at idle; while driving, there are zero problems, zero jerking, nothing at all.
The injectors were replaced with OE Magnelli Marelli ones?
When you took off the inlet manifold did you replace the rubber seal?
¿Se sustituyeron los inyectores por unos Magnelli Marelli originales?
Cuando desmontaste el colector de admisión, ¿cambiaste la junta de goma?
¿Te refieres al grande que va en el colector con los cuatro agujeros... o al de goma semiovalado que va en la parte trasera del motor?
Ambos son originales (compré el Clio nuevo en 2005).
Sí, los cuatro inyectores eran nuevos y originales de Magetti Marelli.
Chasing a hunting idle could be all sorts. To be honest though there are far better people on here than me who have the know how 👍
I've never changed it; in fact, looking at it now, I'd say it's either worn out or there's hardly any trace of it left from the times I've taken the manifold apart... because I don't remember seeing it so exposed as it is in the photo.
For the sake of a very little money it’s probably worth getting.
Yes, you're absolutely right. As I mentioned, I have the large one that goes between the two parts of the intake manifold, and the one in the photo has never been changed; they're the original ones from the car.
Yep, the upper inlet manifold gasket is a piece of cake to change. You will struggle with the lower inlet to engine manifold as there are some awkward bolts to remove as far as I remember.
I installed the new original gasket, part number 8200052311, a little while ago, and it's still the same (the original one was rock hard, but it seems the shaking isn't coming from there).
Is there anyone who can shed some light on this based on their own experience? Thanks.
Injector seals maybe, my 172cup runs perfect with no known faults for years, it also has always had a lumpy idle, I've just accepted that's how it is. I have a 275 megane, that is also the same at idle 🤷‍♂️🫣
Hi, I installed the 4 new original injectors less than 2 years ago... I've been dealing with this problem for a really long time and I can't find the solution... in the end, it's a matter of resigning yourself or keep spending money... the next thing I plan to do is a vacuum test with a smoke machine that will arrive at the workshop soon to see if I can see some light haha
Incorrect cam timing will cause rough idle. Also compression test to make sure all cylinders are within spec
Next week it's going into the shop to check for an air leak... check the timing and inspect the injectors/fuel pump...
There isn't much left to check.
