Cruise control squib
Steve1986
CSF Harvester
Car  Clio 182
I've got someone offering me a steering thing with the cruise control and airbag connectors, but I'm not sure it will fit my 182. Part number is 8200634236, it's missing the steering angle sensor, what I want to know is will I be able to transfer my angle sensor onto it and will my cruise control function? Couldn't care less about the airbags as I have an aftermarket wheel, I just want cruise control for long drives
Some cruise squibs dont have angle sensor iirc
Wire up cruise to audio stalk
Interesting, can I attach an angle sensor to a different squib, and how difficult would it be to wire the cruise to the audio stalk after I'd ripped the connector off?
You can also tap into the squib connector to install CC. (I don't have a squib with black cruise wire from the clock ring)
Right I think I understand now. Seeing as I've still got the working clock spring and squib combo, plus the connectors I accidentally ripped off, my best bet is probably just soldering them back on and being more careful next time.
I just have to dig deep inside myself to find the version of me that last used a soldering iron (it was 26 years ago, I was 14) 🤣
Guess I won't be soldering it back together, I forgot they're stupid plastic covered wires.
I've been looking for a replacement and from what I can see, the cruise squib part number is 8200058677, and the angle sensor is 8200058692. Am I right in assuming I could swap my angle sensor onto a replacement squib?
I've seen the full assembly on breaker sites for £200ish, but I've found the cruise control squib (hopefully in working condition) for £25 on a Polish site 👀
Worst case scenario if it doesn't work then I've wasted £25, but I can't see a reason why it wouldn't?
It looks the same as the £200 ones I've seen around the internet, just missing the angle sensor 🧐
Thoughts?
