First Car Project - Clio 172 PH1
Seconded on this. Came into Clios with minimal mechanical background and my (very limited) car modification knowledge being on old Hondas.
These are easier to work on than '90s Civics, and '90s Civics are literally Lego.
Be reet lad
from the little stuff i’ve done on this and a Clio 182 they are not that bad to work on at all.
I’ve done a few driveshafts now at college and at my old job so it can’t be that much harder. If i can do it on a Transit van, then surely i can do it on a Clio 172.
Exactly that dude, you tend to get into a nice flow state once you've got the fundamentals of the car learned.
Dealing with my completely shot steering rack gave me a decent feel for pretty much how the whole front suspension/steering setup comes apart, which in turn made later jobs way easier.
Sounds like you've got a good head on your shoulders and you'll smash it :)
even more issues seem to have appeared with the Clio now. Which is great.
i’ve got a feeling it’s leaking coolant, when i checked it today it was below the minimum and im pretty sure it was ok the last time i checked it. So i topped it up but i can’t see any external leaks at all apart from the bottle being a bit wet, but i spilled the coolant a bit so i need to check that tomorrow.
While looking for the coolant, i’ve noticed it also has an oil leak, seems to be coming from the sump so probably just needs a new gasket or sealant. I haven not looked into it yet. Everything i seem to look at, another issue appears. It’s something i can easily fix though, so atleast there’s that.
Welcome to Clio life. I just pretend I haven't seen most of it and focus on the thing I'm fixing at the time.
Sometimes I'll go as far as Googling the issue before deciding I really can't be bothered, for example I noticed my selector seal is leaking slightly while I was changing my dogbone mount. Read the words "remove gearbox" and decided I hadn't seen anything after all 🤣
If coolant level is dropping but you see no evidence under the bonnet or car. Check under the dash and see if the carpet is wet. May have a leaking heater matrix/box.
This is basically Clio ownership 101 from what I've discovered.
I did the absolute nightmare job of the steering rack, and was promptly rewarded with the window regulator leaving the chat and a wheel bearing f**king exploding, both within like 4 days lol. I then fixed both of those and it then ate a balljoint immediately
It's never enough to make you go "sod this" and completely throw the toys out the pram, but just enough to keep you in a perpetual pain state
When was the coolant changed? Are you sure there isn't air in the system?
My suspicions are correct with the coolant, i can’t find any external leaks but it had lost a little bit of coolant since i topped it up yesterday.
I took the bleed screw out again and there doesn’t seem to be any bubbles in the stream so hopefully it’s not something serious.
How did you bleed it? Was it run upto temp? Fan on, matrix allowed to fill up?
I followed this bleed procedure exactly, found it on the forums from around 2015:
Undo 10mm nut at the top of the thermostat housing,
Fill coolant tank until a steady stream comes out of said 10mm nut and do it back up,
Leave coolant tank lid off and start car and idle at 2.5k for 4 minutes whilst keeping an eye on the coolant level and keep topping up to the max mark until it bubbles/decreases no more
Put coolant tank lid on,
Idle at 2.5k for 10 or 20 minutes until the fan kicks in,
Turn car off and leave to cool for an hour, recheck and top up if necessary
The heaters blow hot and the fan does work. I’m guessing it’s loosing tiny amounts, it hasn’t dropped a lot since yesterday and that might be why i didn’t notice it.
Thanks for posting the bleed process! i probably should do this with mine rather than just fill it up and hope for the best! tbh that method has always worked in the past.
Regarding the shafts - look up Peter Withers on Facebook, he's the guy that I used (also i think the person that posted the eBay add and did them for the TDC lads).
It'll drop naturally even after that.
good to know thanks.
I’ve topped it back up so i’m just going to check it again tomorrow and let it get up to temp.
I’m going to shove some boots on them and see how it goes. That’s what the majority of people have told me to do rather than swapping the shafts. If that goes wrong, then i’ll send them to him rather then getting a used set.
I take it the car is still up in the air while you sort driveshafts? Sometimes you need a good run with load on the system to get it to settle.
I think it took mine a week as a bubble got caught in the heater matrix. It took a few good pulls to get it shifted and the AC would alternate from hot to cold each pull as the air worked it's way out.
The cars on its wheels at the moment while i get some bits for it and find out whether im taking the shafts to someone or they are coming to me to change the boots.
However the most i can do with it legally is drive it around in circles on the private land the garage is on.
The coolant level dropping has fixed itself. Im guessing that when i’ve taken the bleed screw out again, some airs come out with it so when i’ve gone to check today it’s been no different.
Now it’s just the oil leak, strange squeal from the engine bay and the CV boots and it’s pretty much done. Firstly, it needs them boots fixing.
I think this Clio has a curse against it, i got it out today to give it a bit of a clean and when i was going to put it back into the garage the car and as i was in a rush i left the handbrake on. I know rookie mistake, i thought it will be ok, i was incredibly wrong.
When ive gone to put it into reverse again its sounded like a bag of spanners inside the gear box, the worst noise ive ever heard. so i turned it off and got out to have a little noisy under the car only for me to see that it's blown its own back box. So i took it out of the and went to recreate what's just happened.
Then it got 10x worse as it kept making the noise and got stuck in reverse. I rocked the car back and forth while in the stuck gear, and it again made the horrible noise like there was something rattling around in the gearbox but then it stopped and managed to free its gear linkages up and i could get it into neutral. I decided, ive had too much bad and good luck for today so i pushed it in the garage for another day, so im not too sure if it still makes the noise or not, i didnt want to ruin my day even more if i now have to pull the gearbox out of the thing and rebuild it. Ill soon find out when i do the CV boots.
My guess is that my little brother was slamming it into gears yesterday while he was sat in it and that's done something to the gear linkages and it's gone on me. Possible the something in the gearbox wasn't engaging properly due to the linkages, thus causing the horrible noise within the gearbox. However i could be very wrong. Anyone have any ideas? i cant seem to find anything on the forums. I pray that i dont have a to spend money on a gearbox rebuild or whatever else. It was meant to on for MOT this week. I doubt that's happening now.
From speaking to a few people and looking around at some things i’ve got a feeling that the linkages are at fault not the gearbox.
It only seems to sound like bolts in a washing machine when the clutch is not engaged to the flywheel so it’s like reverse is ‘half’ selected so made the horrible noise. Possibly, due to the age and how long it’s been sat they stuck half in gear and then fully stuck in gear before it moved slowly and selected a gear and ‘fixed itself’.
Anways, if that’s the issue, i’m incredibly lucky and i hope that’s just crunched a little and not a lot. i’m going to check the oil, when i do the CV boots, check the linkages and see if it does it again once i’ve done that.
Update from the Clio, it’s not looking good. I have gone to the car again to check to see if it did what it did yesterday but now i can’t get unstuck out of reverse and i recorded the noise it makes when i push it forward and back when in its stuck position:
Still think it’s a bent linkage? i’m not too sure but it would make sense. Now the key doesn’t work anymore which is great.
so with a bit of messing with the shifter inside the car i managed to get it out of reverse and into neutral. It happily goes into all forward gears but reverse you either need to ram it into gear but either way, it seems to move over to the right, basically halfway between first and reverse.
As for the key, the bonnet sensor is to blame for that. I unplugged it and it’s fine, so that can stay as it is. It’s the least of my worries at the moment.
Disconnect at the gearbox under the car. It sounds like its not aligned properly and sitting half in and out of gear
Yet again, the key issue has reappeared on this car. I’ve been away for the past week in London so i haven’t done anything to it.
Gone to it this afternoon just to see how bad the recent rain has got into the garage it’s living in. It’s a lot . Probably not the best place for it but it won’t be in there long. Anyways, i’ve gone to unlock it and nothings happened at all. it’s been doing this recently so i’ve had to open the door, set the alarm off, then press the unlock button inside the car. It always seems like the issue stemmed from the bonnet sensor, when i pushed down on it with the bonnet up it locked but when it was down it wouldn’t. After that it would be fine.
Now, today was different. My usual ‘fix’ did absolutely nothing at all so i unplugged it and that did absolutely nothing at all. Upon inspecting the plug, a wire comes out of the bonnet cable and into the sensor and the wire that comes out of it was cut and had electrical tape wrapped around the end of it. I can’t seem to find any other wire that it would have connected to at all. It’s very strange as it worked fine, then had gradually got worse and worse till it’s just stopped working again. Perhaps, this was the issue it originally had and the key wasn’t to fault? and when i’ve plugged it back in after doing the radiator it’s fixed it?
Anyone have any ideas what that could be? or what the cut wire should go too?
Key issue is now fixed, i just did the reprogramming thing and it’s happy again however it’s now giving me a solid immobiliser light
It’s done this before, not got a clue how or why it has and how it managed to clear itself last time.
As for the gear linkages, it seems to have fixed itself, happy to go into reverse now. I’m still going to give it a check over though.
Today went horrible wrong, the CV boots don’t fit. I didn’t even get a chance to drain the gearbox oil to see if there’s any issues.
However, the gearbox situation seems to be getting worse. 1st and 2nd spin the wheels but make a horrible noise, reverse doesn’t do anything. I’ve looked at the linkages and i can’t see much wrong at all. At this point i got incredibly fed up on it so didn’t bother checking anything else.
I think i’m just going to send it somewhere at this point.
That sounds like when the selector isn't properly selecting a gear.
If you *almost* get it into a gear it sounds like marbles inside a washing machine. And stacks up why you can't get reverse either.
That’s what i reckon it but i need to properly look into it. When it goes into 1st and 2nd the shifter seems to move to move into more 3rd and 4th kind of area.
My plan is to disconnect the linkage and change gears on the box if it makes the noise again.
More issues, with the Clio. Alarm keeps going off at half 9 this morning. i think the batteries gone flat and has now decided to constantly keep the alarm going. I’m thinking off throwing another battery on it and seeing how it goes.
As for the linkages, i’m currently trying that but i obviously can’t try it without the engine running. Even more proof this car has a curse against it.
