Clio 2 RS undercarriage on 1.2 16V
Car  Clio 2 1.2 16V
Hi all
As strange as this might sound I started to think about replacing whole suspension/undercarriage (and bodykit in the future) on my Clio from standard 1.2 16V to an RS172 or RS182, but id want to keep the original 1.2 16V engine.
You might ask why would I want to do such a stupid thing?
Well there are 3 main reasons:
1. It's my first car, and I absolutely love it
2. I want to improve handling and braking
3. I'll probably buy an actual RS in the future that will be the same colour as this one so people that don't know me won't know if they have been overtaken by a regular Clio or RS one😂😂😂
So here is basically the question I have:
What custom modifications would I need to do to fit the RS parts on 1.2? I know it has discs in the rear instead of drums and mine also has electric steering assist instead of hydraulic one, but doesn't have ABS yet.
My main concern is drive shafts and steering rack, other stuff should just bolt on.
Has anyone done anything similar before?
Thanks for any help in advance😃
Bobi
Hello mate , i kinda done same thing as you but without the exterior bits , converted from drums to rear brakes , Gaz coilovers , front lower arms and brake from 172 but i ve used the engine subframe from my clio and not the 172 one , used my hubs so i can keep my drive shafts and not the 172 ones , i got electric steering too and im ok with it , regarding abs it even better the sensors are kinda expensive and barelly find them ... need more info pls ask .
That's awesome, but I still have a few questions if you don't mind😅
For example do bigger front brake calipers fit on regular 1.2 knuckle/hub?
And also since 172/182 has wider wheelbase did driveshafts had any play, or is subframe the part that makes it wider and not the lower arms?
And did you change steering rack for the 172 as well or did you use your original one?
I probably have a lot more questions but I'm currently just gathering information and not actively working on the project yet, so once I start putting it apart or back together I'll probably ask a few more questions 😅😅
Thanks for the information😃
Bobi
Bobi
I ve used the 172 hub because the gaz suspension has the spacing for 54 mm , the holes where lower wishbone mount for 172/182 they are closer to the edge of those eyelets compared to stock 1.2 or 1.4 , also the lower arms have a different shape and the bolt joint is further out , i used my original steering rack and i ve found that a lot of people do conversions to electric one . Hope that it helps and on my thread i detailed some of the stuff .
Bobi
I've been looking at upgrading the callipers on my 1.6 as well and don't take this as gospel but pretty sure a lot of Peugeot callipers fit the non sport hubs and there are models with 280 ish diameter as per the 172/182.
I was particularly interested in the Brembo four pots which came off the V6 406 Coupe but they don't come up often and seem to be relatively expensive!
Yes there are some calipers that fit but i don t know , im running stock 172/182 front calipers , a bigger brake master cylinder , went from 20mm to 22mm , goodridge hoses and the feeling is sharper also a good set of pads do make a difference , im running stock pads but in the future will get some ds2500
Thanks a lot mate, I've just read your thread and I'm really impressed by your Clingo😃. I think I got enough info to begin my project, and if anything goes sideways I'll deal with it when I face it. Although I was always curious, is the 1.6 16V K4M rear subframe (with discs) exactly the same as 172/182-s? Cause not long ago I got myself a 1.6 K4M Clio for parts(mostly to resell them), but I've kept whole undercarriage and a lot of other parts (front and rear subframe with ABS, front lower arms, hubs, brakes, even some H&R lowering springs). I thought about installing that on my Clio, but I wasn't sure if there is any difference between those parts and parts that I have already installed on my Clio.
Also a few days ago i got myself some original 16inch Renault OZ racing Superturismo rims that I was searching for a long long time😅.
That's for help and greetings from Slovenia.
Bobi
Thanks a lot for the idea, I've read Torvalds's thread, and saw your comment about Peugeot brakes there also. It's a great idea even tho I don't really think I'll need all that much stopping power since I'm keeping it 1.2 16V (75hp) and pretty much stock. I mainly just wanted it to have more or less complete RS undercarriage and bigger discs in the front and discs instead of drums in the back so it looks cooler with those sick rims that I just bought for him(my Clio)😁.
Thanks for help and greetings from Slovenia.
Bobi
Bobi
About the rear subframe i ve removed the drums and mounted the 172 disks and all the associated stuff to make it work on the plus side you get some negative camber on the rear , probably is the same stuff the big difference is in the abs sensors .
If you get more bits keep them stuff like that is like gold .
Oh yeah, makes sense since ABS sensors probably read drum ABS rings differently from disc ones. I also thought about retrofiting 1.6 ABS but I highly doubt it will be compatible with my 1.2 wiring. I'll see what I'll do when I fix my second car and Clio become a full time project car😅. Although I often break cars appart (most crashed or ones not worth saving) for spares, for Clios they are mostly 1.2-s, but I do get some 1.4-s and 1.6-s from time to time, so spares aren't that big of a problem in my case😅.
The difference in abs is teeth number and the clio sport has esp and the sensors are different , i f you don t have abs in your car is ok ... im looking for a pair of abs sensors from 1.6 16v clio with rear disks ...
