Help on compression test on mk3 f4r
Car  Mk3 clio
Hi all, I have a Clio rs mk3 and I have recently put a new engine inside the car after the old one blew up after a day of ownership and this engine I have put in has broken down again and is no longer starting I can’t remember what I done last to diagnose but I know the next step is a compression test how would I go about doing one and what numbers would I be looking for good compression and what numbers should I be worried about any help would be appreciated TIA
Warm engine, all plugs out, coil and injector connectors unplugged, throttle held open, crank each cylinder until the gauge stops climbing. Healthy F4Rs read roughly 170–190 psi, all four within about 10%. Below 140 or one cylinder well down is the worry zone. A little oil in a low bore and a retest separates rings from valves.
What else have you done to diagnose it? I wouldn't be jumping straight to a compression test personally without lots of other checks first.
