aint it somet to do with oil,
could i be losing half of my petrol down it?
You won't see much.I've got an OBDII connector thing if you wanna give it a try see if you can do any diagnostics with it?
its going somewhere.
sounds like it limiting early but im guessing its either starving or being flooded of/with petrol.
+ 150-180 miles on a tank its like owning a vee and only having first!
You won't see much.
Have you tried the dashboard trick shows how much fuel the pump is pushing when your driving along.
Does the car idle well?
Check your spark plug they might be dirty indicating overfuleing hence a MAp or lambeda sensor possible problem.
Fuel flow (the engine has to be running. This is in liters per hour
what should it be readng then eddie?
its really irratic and i cant tell when revs or speed im doing when its doing that reading.
the most i saw 23 odd when i booted it.
