Cost of fitting
Alloys take a few minutes just do that yourself headlinght are easyish just need to remove the front bumper.
Just bulbs or the full unit? If your not used to it then allow 45 minutes to do the wheels although you can easily do it in about 20-25 minutes. Bulbs are no hassle and full headlight units take a bit more time as you need to align them
Ok, thanks. I have NO knowledge of body work, mechanics, cars etc. All I know is what looks good and what doesn't! So, you think it would be best to do it myself? Any guides out there to help?
What's involved? My priority is getting the wheels sorted.
Loosen bolts slightly, jack car up, take wheel off put new one on with bolts a bit more than finger tight, lower it, fully tighten bolts
Sounds easy enough! Another question, how do I ensure I get the right size wheels? What's compatible and what's not?
on yours probably 14" steels or alloys. For handling 15" is bes for looks I prefer 16" over 17". Go have a look at picturesin the media section and see what you fancy
