The digital dash's
Da
Car  Less
on the mk2 ph2, were they ever introduced to the RenaultSport range and if so at what age?
If not is the trip computer displayed on the odometer readout?
They dont seem to be interchangable either.
I have a set of normal Dynamique display and a newer digital dash.
Same block connectors etc....
But the fitting is different not allowing them to connect.
Yep wiring is different in them you could make one work. jsut need to cut and swop the wires.
Yer i did notice.
Infact i did consider doing it but i really prefer the Dynamique ones. Look smarter in the flesh. The digital ones need the dunamique surround me thinks...
But yes the connectors can be individually be pulled out (no cutting involved) then re-inserted in the correct order.
Would need a wiring guide and patience hehe.
Bit off-topic here and maybe a bit silly..
Is it possible to fit the digital dash from another make of car?
(providing it had the engine from that car)
I'm loving the new Civic dash :)
if only I could afford to stick it's derv engine in the Clio too :evil:
