forum
  Fiat Panda 100hp
I need a forum for my site, I can have PHP with my host, the forum must be free, what would people suggest?
  Fiat Panda 100hp
Okay people, I need some help. I have setup SMF, but not very far.
I need to know what to put in the SMF installer page, below are screeenshots of this and also a screenshot from my CP that shows MySQL 4 installed.
Anyone any ideas?
  Not a Clio
Are you getting an error?
MySQL Servername - I used "localhost"
I assume you have setup a user and database already and aren't just putting what you like in the other fields?
According to that form, server name should be: sql02
Database name should be: bw-forum
Read the screen! :p
  Fiat Panda 100hp
Read the screen! :p
I have tried entering spl02 as the server name, and it didnt work, plus it says do that for scripts, I dont know what this means, and wouldnt it be better doing the 2nd option, which is connect from my PC?
Error is attached.
  Citroen DS3 DSport
Yeah it's SMF I always use for the various forums I have set up over the past 3 year. Brilliant piece of software and very reliable.
  Not a Clio
Just a suggestion, but unless you are planning on adding more categories, I would group your existing ones into one table as it looks a bit busy at the moment.
Take a look at themes as well, whislt the default is very practical, it's a tad dull.
Here's a snapshot of the forum I run for my other half. It's SMF + TP.
  Not a Clio
Do you mean theme SMF or customise a theme?
To theme it all you do is download the one you want, upload it and select it.
Customising depends on the theme, some are really simple and some take a bit of head scratching.
Also, if you use TP as well as SMF then you need to look at TP themes as they also theme SMF. An SMF theme will not theme TP.
  Fiat Panda 100hp
Yer, I want to customise so the forum says bw online at the top thats all really. I looked at the customizing bit and it just gave me a bunch of code. Dont know where to start
  Not a Clio
Ah in that case all you need to do is...
Admin -> Server Settings -> Forum Title
No need to manually edit any files for that :)
Like your new theme! If you want to replace SMF Millenium then that's a graphic you will need to edit. (/Themes/2k/images/img/topl.jpg)
  Fiat Panda 100hp
Like your new theme! If you want to replace SMF Millenium then that's a graphic you will need to edit. (Themes/2k/images/img/topl.jpg)
Nice one J, thanks alot.
  Not a Clio
Isn't much incentive to join to be honest.
Other forums cover your categories.
It's not easy getting members unless you are specialist e.g. Clio owners
