What will I need to make this fit?
And how much will they weight roughly?
My car is stripped so don't want to go and make it 20kg heavier again...
Thanks
Sam
yer really easy
Red power cable to battery
Aux lead from amp to headunit
ground wire some where in the boot any where metal
blue rem wire to headunit
simple job done
This is in a mk2 ph2 yeah?
What sort 5kgs?
And how good are they?
How much better will the sound be than standard?
Thanks
Sam
if i was ou i wouldnt even get a sub if your car is stripped! where abouts will the box go? it will be flying about everywhere when you turn accellerate or brake?? plus you wont even relise the extra weight anyway
How much do they weigh though?
I was goign to just going to tie it all down to all the whole left in the back since I took out the seats.
Sam
find out how much each sub weighs, how big the box is and how thick the wood is and then you can estimate how much is weighs
Sounds good Alex, but I have superleggys on there at the moment and IIRC they are just about the lightest alloy around?
Sam
Yeah but it will weigh around 20kg from what people have said?
I cba with that to be honest.
With a 1.2 I need as little weight as possible to get it to 60 let alone get there in a respectable time.
Sam
its not going to make no difference at all tbh. you wont notice that you have it in the car apart from a big box sitting in the back :). mine weighs alot more and ive got all my interior in and it hasnt slowed me down 1 bit
i know the infinty kappa perfect 12 vq weights 10Kg on it's own(about the same for the 12.1) + 10Kg for the box atlest
so yeah 20Kg's is about right
also the sub isn't 500w RMS (it'll be 400 at the most;) )
