Suspension Spacing mk1 ph3
mines 58mm and is a mk1 phase 3 's', you need to get under it with a tape measure and find out there all different depending on what the renault monkey was smoking that day!!
centre to centre of the bolt should give you the correct spacing on the bottom of the strut, good luck had to get mine specially made from koni as they had only produced one before with a 58mm spacing, no one would believe me that it was 58mm renault didnt even wanna talk to me!!
good luck ;)
Couldn't they have done them all the same?
Got a Mk1 Ph3 's' aswell hoping it is not going to be 58mm!!
