Amp Audio Outputs?
Car  Renault meggy
I have spent this afternoon sorting out my sound system in my car. (getting the bass level setup right ect...)
Anyway, when I was ajusting the amp I found two audio outputs (White and Red) next to where the two red and white cables connect from the head unit in to the amp.
What can I use these outputs for?
Thanks,
Hixxey
Sorry my camera is playing up this is the best I can get
The writing reads:
Line Out Input
Right O O
Left O O
its a line out for another amp
Thanks. I wanting to get some 6x9's friday but not sure what I can connect them up to. I currently have my two front and right 13cm door speakers attached to my head unit and This amp + sub also connected to the head unit.
Will I have to buy another amp and connect it to this one to be able to have 6x9's or can I somehow have them without a new amp?
BTW, This is my head unit if it helps in answering my question.
Thanks,
Hixxey
Line outs for adding another amp as said above
Don't get the 6x9s mate.
What speakers have you got in the front and what sort of budjet are you on?
just get speakers that fit in the rear 6x9's are s**t tbh you'll get a good set of components or coxials for £100 imo i would amp them but if it was me id get a seperate amp
12" 1250 w Infinity Sub
Frequency Response: 25 - 400hz
Power Range: 60-300 watts Rms (1000 watt max power)
Sensitivity: 93db
Inpedance:4 ohms
And my amp is,
1 or 2 or 3 channel for Dual Subwoofer or Sub and Mains Speaker +
Achievement 1000 Watts music Mono- bridgable up to 400 W RMS Multi-fashions
Subwoofer Crossover Frequency adjustable (40 to 250 Hz)
