Spax
Car  Clio 1.2 16v Dynamique
Soon Ill be after some spax or similar 60mm springs for my 1.2. Anyone know a good place to get them from??
Cheers,
Alex.
Edde, what would you go with if apex werent available to lower about 40mm? On standard shocks too.
Ta muchly
Spax are totally over-rated. Best manufacturers are eibach or cobra
Also if your going for a 60mm drop you'll need dampers also. Otherwise the stock dampers will be stretched when going over speed bumps etc
There no such rule like -60 means new dapers you should change them when you chnage shocks anyway.
if i wanted a 35mm drop with springs, would that be ok? like still possible without complete coilover set or new shocks
