help needed with Burning BIN/CUE Images movie onto dvd
Car  Jap Shed
I have a problem, i have a movie to burn but the files i have are a BIN file and image file a tutorial says to -
Verify the CUE-sheet and open it with Nero
Before doing anything else you have to verify that the path in the CUE-sheet is correct. A CUE-sheet is a plaintext file describing the structure and the location of the BIN-file. You can open up the .CUE -file using, for example, Notepad.
The file should look something like this:
FILE "IMAGE.BIN" BINARY
TRACK 01 MODE1/2352
INDEX 01 00:00:00
I dont have a clue what this means!!! anyone help please?:S
the cue file is like a shortcut to the main movie file , and contains some settings for the burn type. Is this def a DVD how bigs the bin file
FILE "IMAGE.BIN" BINARY IMAGE.BIN is the main data file
TRACK 01 MODE1/2352 tells it what setting to burn on for file structure etc
INDEX 01 00:00:00 tyells it where to start burning on the disc
if the path is set to
FILE "IMAGE.BIN" BINARY it referes to this file been in the same directory as the cue file , the recording software wud pop a error up saying cant find the bin if its not there , so u`d then manually select the file
FILE "c:\IMAGE.BIN" BINARY if it looked like this then it would look directly in yer hard drive . which wouldnt be where u downloaded it
Extract to movie using ISOBuster
Its in the MPEGAV folder and named eiter AVSEQ0001.DAT / .MPG
Right click this and select ---> Extarct (something) M2F2 Frames
Do this for each cd, naming the output files movie1/2/3 etc.
Load these into VSO's DivX2DVD and convert
Or pay £20 and get SVCD2DVD and dont bother with the extraction.
Just use Nero Select DVD then Burn an Image point it to the CUE sheet and it will burn the BIN file according the settings in the CUE file thats it. You have a DVD with what you want on it.
usually though the films are in ISO format when on DVD but it doesnt matter to be honest.
