New Design Samco Inlet Bend
Yeah mate they are available but will take 5weeks as they are made to order.
I can get them through work they cost around £62.12. I have been temted to get one for the Trophy as it comes with the breather pipe already attached, and saves getting a piece of straight Samco for the breather pipe.
Drop me a PM
far better - is 4 layers thick instead of 2, has an oil resistant layer on the inside which the hill power doesnt. the inside is far smoother/neater = better air flow, plus has the breather all built in.
Has anyone else noticed that the top of the breather pipe rubs against the bonnet lining? mine has a small friction burn on it :( Will need to tweek it about me thinks...
Anyone fitted? Would like to know some comments on this.
I know it should be better cos of the inner surface got smoother. But how's the different?? Or just look good :-P
Haven't fitted one but 60 quid is a lot of money for cosmetics
Good s**t though if you have spent loads of money on engine detailing etc
I have one fitted running the standard air box and K&N panel filter, it does make a difference as the internal bore is smooth so allows the flow of air the run faster with less turbulance.
I doubt that there will be any notable gains, but in theroy it should allow the air to flow better so it cant be a bad thing.
unlikely to make any gains on the dyno though even though it's smoother on the inside than the OE one.
Looks very nice though, just wish it was a little cheaper but I suppose it's cheaper than the Subaru ones which cost over £200
Ha Special Offer, I just bought mine through work at cost, complained about the fit, and Samco sent me another one. Thats the benefit of working in the performance parts and accesories market.
