Help...Standard 182 Alarm
Car  CLIO 182
I was wondering if anyone could help
Had my standard 182 a week now and not had a problem with it but this mrning the car alarm started going off for reason it was really early so i just went out unlocked the car then locked it again...but half an hour later it went of again.
I have not got a clue how it has all of a sudden started going off!!:S
Any help would be great
Thanks
did you check the status LED, it should flash to show you what trigger activated the alarm
should be buy the gear stick, a little red LED when you disarm and turn the ignition on it should flash a number of times, count the flashes and look in the alarm manual (should be in your leather renault wallet thingy) and it will tell you what caused the alarm to trigger.
also did you have anything in the car which could of caused disturbance?
The ultrasonics can be very sensitive and something like fluffy dice/air freshner hanging from somewhere could of moved and set the sensor off.
