Kw's help!!
Car  Racing blue 182 turbo :-)
I have just ordered KW coilovers they are coming from Germany how long will they take to come does anyone know??
should have said on the site you ordered?! :S check the invoice maybe, might say on there...?! ring them up..
mine took about five weeks, but they were ordered from the competition department at the start of racing season, so they were probably at the bottom of the list.
Beware of these, Mark's rear dampers knocked like fook and had NO travel. The fronts feel uber nice though!
fronts = perfect
rears = spring is linear with no movement so therefore the damper has zero movement making them extremely uncomfortable. rattle like fook due to the rose joint mechanism joining the damper to the axle.
and to top it all the rear only lowers a MAXIMUM of 15mm. the 25mm they state it rubbish
Told you!
We changed his Rear dampers AND springs to koni yellow's and Sportlines.
As above, fronts are really good but the back's are utter poo
you can go for custom springs but it doesnt change the fact the dampers still have zero, and mini-valver will vouch for it, travel.
so ive had to replace the springs on the back with sportlines and the dampers with koni yellows to retain the flexibility of damper adjusability to go with the fronts.
How long have you had the KW's??
