When i break, my rear fog light comes on, on the dashboard?
Haw e haw e haw ;)
Loose connection going into the display or a loose/earthed wire somewhere?
I have the same problem, mine flashes sometimes as the indicator flashes too, its only ever when indicating right. I was unable to locate the earth for the light but I think ill have a look where edde said. Hope it fixs the problem for me :)
i had the same problem with my i had to change the back light wiring loom becuase the water had got into the wiring .
When you open the boot, pull back the carpet in the RH corner, you should see the black wire coming down from the light. I tried cleaning the earth which didnt work but then new bulbs fitted and this eliminated the fog warning light flashing problem, but when the indicator comes on my sidelight still goes dim. Any ideas?
mine did this,took the plugs off the bk of both rear lights,gave them a quick clean,and problem sorted.easy fix
Clean the block plug terminals on both rear light clusters, get rid of all the crap in there, tighten the terminals, and clean the earth strap again.
Thank you so much, this was driving me mad for ages. I had it when I braked, indicated and reversed. I cleaned the earth connectors on both light clusters and it seems to have done the trick. very happy :D
cheers guys
