use of edge pads
Car  172 cup
any thoughts of this pad and system on rotery and pc /whot best to use thinking of trying roatry again can not get results with g3 just a mess a trails every were:clown:
Just bought 2 edge pads today 5in. Cutting and mild cut. Miles better than the sonus imo. Plus you can flip them over and use them as another pad! I'm chuft to bits.
thanks for reply have you used them if so with wot products,were did you buy ,thanks:rolleyes:
Carwashnwax, CS members get a discount from david.
Products vary from car to car, so it's imposible to say...Tomo's process on the vee will be a 1500grit polish from CG is that doesn't work then the intensive menzerna. Final stage on the green edge pad.
