Autoglym Aqua wax
Car  titanic killer
Anyone tried this product yet? Sounds quite easy product to use as im not clued up on waxes but it says you can use this while the car is wet so it eliminats the need for drying
Doesn't eliminate the need for drying, just means you don't need to wax afterwards is the idea if it's like the ones I've tried.
I've used the Duragloss and Prima versions of it when I've not had time to wax the car properly.
duragloss aquawax is good stuff, wont give u an increcible shine but good beading and a nice finish
We have the trade version (basically the same stuff) called Autoglym Express Wax and i use it as a fast and easy to use sealant for when the car has been chamois dried.
Gives good beading and water run off.
Another Autoglym product i use is Liquid Hardwax which is basically a more durable high gloss sealant.
Funnily enough it smells exactly and has the same watery consistency as the bodywork treatment you get with the Lifeshine kits....
bencleland;How well would this jeffs bond over something like srp? Can you use this over egp aswell or would your need to clay first and use something different underneith for the base?
I remember Rich describing the Jeffs like a sprayable EGP, so over SRP it would be good.
The Jeffs will bond lovely over the SRP. It is basically a reformulated version of Klasse Sealant Glaze which is more user friendly and sprayable. Klasse SG is best looked at as the German Version of EGP. I have used the Jeffs AGT over Klasse AIO and Carlack 68 as well as SRP. All worked well.
